Part 2: PNP Removal
chrillew
Year and Model: volvo 850 T-5R 1995
Post by chrillew »
I cant find any dialectric grease in my town. does any else grease work aswell? or has it to be a dielectric grease ?
Steve Ivins
Year and Model: 850 t5 1994
Post by Steve Ivins »
Dielectric grease is also known as Thermal Transfer Paste. It's zinc grease.
chrillew
Post by chrillew »
thermal transfer paste, thats like paste for computers, on cpu coolers etc? and when i search on zink grease in our country i only get skin lotions haha..
Been thanked: 504 times
Post by cn90 »
The last time I did this PNP thingy 2 years ago, I used regular grease, zero problems so far.
The voltage is so low (12V), so standard grease is fine. Don't over-analyze this thingy.
chrillew
Post by chrillew »
yeah i used just a normal grease i had, works perfect.
Dcadizel
Year and Model: xc70 3.2 2010
Post by Dcadizel »
4 years later and i found it so useful, thanks Marcin for posting this up! This one was my last thing in 200 k tuneup.
- Dawid
gk800b
Year and Model: 1996 850 GLT
Post by gk800b »
Great instructions on doing my own PNP cleaning due to flashing orange arrow. However, I carefully marked and put back everything back as close to as I took it out. Everything seemed fine but when I test drove the car in D it did not want to shift out of first gear. When I set it to 3 it seemed to go through a couple gears. So not being a mechanic I am assuming I have some issue with the switch but not really sure how the switch works. Can the switch being slightly off keep the D in first gear?
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Yes, I think if the switch isn't aligned correctly it can leave the car stuck in one gear. If that were the case I would expect your up arrow to be on though.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
Removed my pnp switch today, intending to repair it, only to find it is to fubar'd to repair.
My real problem is that the previous owner nearly ruined the connector with the clip side, see picture:
It is connected to this black plug next to the shaft where the pnp is mounted. I would like to replace that (even though it still seems to work) - seems to be this partnumber: 8636318
Can I replace this without opening the transmission? from the picture it seems like there are a number of connectors inside the transmission that connect to this, not sure If I got that right? If this is just straight forward plug and play I would invest the money and fix it. If it is more work I would let it be.
If you know how to replace this please let me know.
850 T5-R '95 auto Image
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
polskamafia mjl wrote: Alignment and Reinstallation:
Unfortunately I was not able to use MIJ’s method for alignment. I don’t understand how he
gets the reverse lights to work with the battery out of the car. So, with no other options, I kept
things simple. The Volvo tool aligns the middle bolt with the groove going down the middle of
the PNP housing. So, I decided to get as close to parallel between the 2 w/o using a Volvo
alignment tool. Here is a picture of what I mean.
So what to do. Put the shifter in Neutral. Align the PNP switch as shown, and screw the shifter cable down into place. Then bolt the cable arm to the central bolt of the PNP. [...]
The step highlighted red needs some clarity...assuming the step is key part of Alignment and Reinstallation, I ask those with this repair:
1) where is "Put the shifter in Neutral" applied, is it at the gear shift lever inside the car?
2) wasn't the Shifter at N - Neutral at the outset of this repair?
