Part 2: PNP Removal
Steve Ivins
- Year and Model: 850 t5 1994
Dielectric grease is also known as Thermal Transfer Paste. It's zinc grease.
- Been thanked: 504 times
The last time I did this PNP thingy 2 years ago, I used regular grease, zero problems so far.
The voltage is so low (12V), so standard grease is fine. Don't over-analyze this thingy.
Great instructions on doing my own PNP cleaning due to flashing orange arrow. However, I carefully marked and put back everything back as close to as I took it out. Everything seemed fine but when I test drove the car in D it did not want to shift out of first gear. When I set it to 3 it seemed to go through a couple gears. So not being a mechanic I am assuming I have some issue with the switch but not really sure how the switch works. Can the switch being slightly off keep the D in first gear?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Yes, I think if the switch isn't aligned correctly it can leave the car stuck in one gear. If that were the case I would expect your up arrow to be on though.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 85 times
Removed my pnp switch today, intending to repair it, only to find it is to fubar'd to repair.
My real problem is that the previous owner nearly ruined the connector with the clip side, see picture:
It is connected to this black plug next to the shaft where the pnp is mounted. I would like to replace that (even though it still seems to work) - seems to be this partnumber: 8636318
Can I replace this without opening the transmission? from the picture it seems like there are a number of connectors inside the transmission that connect to this, not sure If I got that right? If this is just straight forward plug and play I would invest the money and fix it. If it is more work I would let it be.
If you know how to replace this please let me know.
850 T5-R '95 auto
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The step highlighted red needs some clarity...assuming the step is key part of Alignment and Reinstallation, I ask those with this repair:polskamafia mjl wrote: Alignment and Reinstallation:
Unfortunately I was not able to use MIJ’s method for alignment. I don’t understand how he
gets the reverse lights to work with the battery out of the car. So, with no other options, I kept
things simple. The Volvo tool aligns the middle bolt with the groove going down the middle of
the PNP housing. So, I decided to get as close to parallel between the 2 w/o using a Volvo
alignment tool. Here is a picture of what I mean.
So what to do. Put the shifter in Neutral. Align the PNP switch as shown, and screw the shifter cable down into place. Then bolt the cable arm to the central bolt of the PNP. [...]
1) where is "Put the shifter in Neutral" applied, is it at the gear shift lever inside the car?
2) wasn't the Shifter at N - Neutral at the outset of this repair?
