1994 850 wont start
michaelw84
- Year and Model: 2000 s70
i have tried just about everything except fuel pressure at injectors,, how much pressure should be there and where can I find a gauge to use.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
It's best to listen for the pump. When you press the valve at the end of the rail, you should get a nice little quick squirt. If it doesn't squirt, you likely have a relay or pump issue.
als98volvo
- Year and Model: 1998 Volvo V70 GLT
Check your MAF (Mass Air Flow Sensor). My car would not start recently and it seemed like a fuel problem. It acted like it wanted to start but wouldn't and when it would, it would run a few seconds then shut off. It was not fuel related but, instead something simple but, initially overlooked. The MAF is located on the air intake, just north of the filter with a plug attached. Disconnect and see if car starts. If it does, then your MAF is bad. Otherwise, follow "rspi" advice, troubleshooting your fuel system. He does a good job explaining the testing procedures.
'98 V70 GLT
'96 F250 XLT SUPERCAB 4X4 7.3L DIESEL
'54 WILLYS PICKUP
'54 WILLYS PICKUP
michaelw84
ok i checked everything maf sensor is good i have a good spark i have good fuel pressure, timing is good and so is compression.. i do have two fualts in code system, # 1 comes up as idle air control which i disconnected while trying to troubleshoot so thats most likely why it falted but i did replace with a known good unit and same result, # 2 comes up as EGR system faulty now my question is could be a bad EGR valve if so how do i check and also could it be a bad ignition ECU that actually controls the EGR
- Has thanked: 1611 times
- Been thanked: 4074 times
Please review 'proper formatting of post' rules at the top of the Forum.
I suspect you have an ignition problem leading to a no-spark condition rather than an ECU problem. ECU failures on these cars are extremely rare.
michaelw84
i do have a spark though,would a clogged EGR cause it not to start or just run rough
- 1229 Views
Last post by whtwgn
- 25 Replies
- 8725 Views
Last post by AmericanT4
- 510 Views
Last post by screwdriver
- 27 Replies
- 3720 Views
- 508 Views
Last post by Turbobrick69
