06 S60 Low coolant light in extreme cold weather
toxtreme
- Year and Model: 00S80, 05XC90, 06S60
So I started my S60 this morning (-5 deg) outside and car was on a slight decline (engine on downward point in parkinglot) and the "low coolant" red triangle appeared, I let it run for like 1 minute then turned the car off, waited about 30sec and restarted car, light didn't come back on, I drove the car for about 35 minutes to work and checked the level, it was about 1/2" above min, I see on other google searches that people mention that the coolant may be contracting in the extreme cold weather, just wondering if anyone else has encountered this issue and if it is normal and what I should do?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
it is contracting however the level is a bit low anyway, you may add a bit of distillate water or coolant mixture about 5oz
it doesn't hurt the engine to have the coolant low for a moment
Same thing happened to wife when in middle of nowhere she got some no name coolant.., it was at minimum so barely needed to add anything.
I would just go to parts store buy something "ok for Volvo" name brand type.
- oragex
I'd keep an eye on the coolant level. if it drops a little it might be leaking somewhere. if mileage is higher than 150k, it'd be a good idea to check the water pump for leaks.
- 9 Replies
- 1180 Views
Last post by Scruffy
- 2819 Views
Last post by poconosms1
- 4033 Views
Last post by MathalomuleM31
- 698 Views
Last post by MoVolvos
- 1022 Views
Last post by Sommerfeldt
