DIY: 1998 S70 Dash Rattle Ghetto Fix! Topic is solved
Been thanked: 504 times
Post by cn90 »
Most people here are familiar with Ozark Lee Dash Rattle Fix.
There are 2 versions of repair: version 1 and version 2; you can read more below:
Dashboard Mount Repair - Version 2.0
https://www.matthewsvolvosite.com/forums ... =1&t=58347
My 1998 S70 is now for my kids to use for high-school. I simply don't have 6-8h to take the dash apart, so I resort to a "Ghetto" Fix. Surprisingly, the result is very good, no more noise after I did this fix.
So, I want to dedicate a thread just on "ghetto" techniques for dash rattle.
This DIY only takes 10 minutes or so, skill level is 1/10, super easy.
1. To test the theory, I installed some cardboard as shown and sure enough, the noise is gone:
2. All you need is "Butyl Rope", the stuff auto glass shops use to attach windshield glass to older Chevy Ford models many years ago. You can buy them at local glass shop for about $10 for a roll of 10 feet or so. This is in fact used on other parts of the car (vapor barrier etc.), so you can use it for other jobs too.
3. On both sides of the dash, at your shin level, there is a Torx screw. Tighten it.
Then apply a small bead of Butyl Rope as shown:
Easy peasy, noise is gone...
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Please update us in 30 and 60 days. I'm afraid that it will push the dash away from the firewall.
Has thanked: 311 times
Been thanked: 817 times
Might this put additional stress on the already breaking mounts, making things worse rather than better?
Post by cn90 »
So far so good, zero rattle. This stuff is like chewing gum, I just put a dab as shown.
Almost no stress on the dash at all.
Aha, OK. I want to give this a try, thanks.
Ben850
Been thanked: 7 times
Post by Ben850 »
I had the dash pad out of the wagon to pull the instrument cluster and replace the odometer gear, so I took advantage of the opportunity to help out my sagging, bouncy dash.
Replacing cluster with its  new odometer gear.
Passengers side Where cn90 pointed out the torx screw, I removed that screw and lifted the whole dash almost an inch. I then drilled a new hole at that point and screwed it back in.
Raised this screw almost an inch.
Then at the topside of that same metal bracket that holds up the dash I drilled a completely new hole in the bracket and straight into the door jamb area at the A pillar. I used washers to space it correctly as to not pull the dash too tightly and contorted out of its original position.
Washers helped hold the original position.
I repeated on the other side and the dash is now quiet and motionless.
I still plan on doing something at the firewall when I am in that area again.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Post by cn90 »
Hi Ben,
Thanks for the "ghetto" idea. I like it.
As I mentioned above, I simply don't have the appetite to spend 6-8h to pull the dash out...
Ben850
Post by Ben850 »
cn90 wrote:Hi Ben,
This took me less than 2 hours total, including replacing the instrument cluster and taking pictures. Not too bad. (Add another 1/2 hr. for odometer gear.)
Of course I have experience getting the dash pad off between the Sedans accident and odometer fix, and quickly getting them off donor vehicles.
singood
Year and Model: S70, 1998
Post by singood »
I ghetto fixed my Volvo's squeaks by using regular plastic shims, wedged between the dash and the a pillars on the sides.
I used about three shims on each side of the dash and took it for a test ride - love the quiet! Hopefully the shims do not place too much pressure on any other fastening points and will remain long term...
cdnbluez
Year and Model: 09 C30/98 V70/99 S70
Been thanked: 3 times
Post by cdnbluez »
The real "ghetto fix" is to pull the bolts from the firewall and use some spray foam insulation in each hole. Get back inside the car and put pressure on the dash until the foam sets. Let it cure overnight.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
