... this thing is always going to leak ..MVSUCCESS !!
Been thanked: 472 times
Re: ... this thing is always going to leak ..MVSUCCESS !!
Post by cn90 »
MadeInJapan wrote:...I suspect it's the Front cam seals – they reused them when they redid the head. In everyone's opinion who makes the best front cam seals? Where do you buy them?
You can use either Volvo or SKF. I have one Volvo and one SKF seal right now in my 98 S70 GLT.
I wrote detail instructions below:
DIY: 1998 Volvo S70 Timing Belt, WP, Cam Seals, SB Overhaul
https://www.matthewsvolvosite.com/forums ... hp?t=53722
The key thing:
- Front cam seal SKF 17806…Napa auto parts $15
- Use Plumbing PVC Coupler to drive them in, it is very tricky for the Exhaust-side seal.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Thanks- local dealer wants $25 each for those
MadeInJapan
Do you have coupler diameter, part number, description etc?
MadeInJapan
Oh and are people having issue with Erling they sell on line?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
MadeInJapan wrote:Oh and are people having issue with Erling they sell on line?
Yes - mine blew out again. Avoid those.
'98 S70 T5
2016 Chevy Cruze Premier
MadeInJapan
Thanks
Post by cn90 »
MadeInJapan wrote:Do you have coupler diameter, part number, description etc?
Info in the thread above.
You can always get the SKF seal, then bring it to hardware store and find the correct PVC coupler.
But read that link carefully on the cam seal tips/tricks.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
32mm or 36mm socket would work also.
MadeInJapan
Took the TB off and replaced the suspected cam seals and after everything is back together there's still a leak - a bad leak! Turns out it's the corner cam cover bolt nearest the front exhaust cam seal- It will not tighten to spec-it is stripped. Any suggestions now??
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
These are all M7 X 1.0mm pitch threads.
They lend themselves very well to an increase in size to M8 X 1.0mm. Just use compressed air to blow out each time you drill or tap threads.
The top cam cover's hole can be increased to 9.5mm
Be sure not to drill down into the cam area; always drill with tape on the drill bit to show how far to go.
I did 46 of them over a day on a 960....phew :)
