Looking for Wagon - Manual Transmission
luvmy544
Year and Model: '63 544 '91 240
Post by luvmy544 »
Please help me find my 4th Volvo...
Looking for a Volvo wagon for my son. Would prefer an older V70 or V70XC. Would also consider a 240, but would prefer 1990-1993 so as to have an airbag. Must have a manual transmission, not interested in a semi-automatic or the good old 4-speed w/overdrive found in so many of the 240s.
Thanx!
'63 544 (450K+)
'83 DL (240) Diesel Wagon (long since gone in a puff of black smoke)
'91 240 Wagon (250K)
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The 5 speeds are far less reliable than the 4+OD. They have a 1 st gear brake to squelch gear rattle and use a plastic needle bearing cage inside 1 st gear.
IF you get a 5 speed immediately drain it and out in 10w30 synthetic oil or Redline MTL.
luvmy544
Post by luvmy544 »
jimmy57 wrote:The 5 speeds are far less reliable than the 4+OD. They have a 1 st gear brake to squelch gear rattle and use a plastic needle bearing cage inside 1 st gear.
Thanx for the information on the plastic bearing. Have to say though that I have never had a problem with either of my 5-speeds (250K and still going strong on my '91 240 Wagon - knock on wood), but have had the OD go out in the 4-speed w/OD. Speaking of which, I have that 4-speed w/OD transmission sitting in my side yard if anyone wants it. Free to a good home.
luvmy544
Post by luvmy544 »
Wanted to thank everyone for the help. I found a beautiful Nautic Blue (or Tardis Blue) 1998 V70 with 142K.
jimmy57
Post by jimmy57 »
The issues with 5 speed RWD M47II trans was usually due to oil changes with ATF. The thrust bearing for 1st gear would gall and heat the gear until the bearing cage failes and failed bearing. That is the issue seen in hot weather climates. If other oils were used then the gearbox failure is nil.
Has thanked: 1511 times
Been thanked: 3827 times
luvmy544 wrote:Wanted to thank everyone for the help. I found a beautiful Nautic Blue (or Tardis Blue) 1998 V70 with 142K.
Not as pretty as my Midnight Blue 99 T5 stick but you are probably better looking than I.
We will call it a draw.
Has thanked: 294 times
Been thanked: 767 times
My first 850 wagon was Nautic Blue, it's a great color. Enjoy!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
OP....scan v70 forum for a recent thread on a v70 manual for sale..I'll link when I can find it, username was osman
ummm ...
OP is already happily wed to that.
'06 S60 R, 197k
ECU glitch, carry on...
