Slow progress. Here are few photos.
The coupler at each is welded. I imagine cutting the welds to remote the coupler?
1997 Volvo 850/na - Fitment and make of exhaust muffler
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
xHeart
The picture shows a 10mm gap, it is a tear on old coupler. Pushing each ends upward narrows the gap.
I have raise the car further up, clearing anther two inches to work from under.
Assessing if hangers need to come down and off.
The snow storm adds to anxiety.
xHeart
A frustrated afternoon with a snow dump.
Nonetheless, the coupler inside the exhaust is stubborn. I have separated the exhaust lip from the coupler layer to see if there is a weld getting in the way from sliding out.
Few photos of progress. I will files the exhaust lip before installing new coupler.
Any pointer for removing the coupler?
I don't believe this how the original installed?
- Been thanked: 504 times
xHeart,
You are funny, very persistent person.
I had the same exact issue, my advice is: go to local muffler shop (it will be noisy driving there lol).
They will use a metal sleeve coupler, weld it in, charge you $60 and you will be fine for another 4-5 years.
Anything else you do at home is a band-aid and a waste of time.
xHeart
I am leaning that way cn90.cn90 wrote:xHeart,
Preparing to take "sky is falling" story at the muf shop.
Many thanks
xHeart
I say, it was best spent $65 after $140 on exhaust manifold in Fall 2013
A quieter drive afterward.
Thank you!
Thank you!
xHeart
The muffler is making noise again.
xHeart
My muffler problem has returned 6 month after the chain store's welding.Ozark Lee wrote:I replaced a Bosal on my son's car. The pipes were pristine but the muffler itself had rotted in half and the hanger arms rusted off of the body. The back pipe can be repaired with a chunk of tailpipe, a coupler, and a couple of clamps. [...]
The pipe diameters will vary depending on what kind of muffler you have now. I left the Bosal pipe from the joint between the catalytic converter to the muffler but it was a larger diameter than the stock pipe so I used an adapter coupler.
The new Bosal is $25 cheaper than the OEM Starla $223.
I would prefer using clamp connecting it at CAT.
Who would know if Starla is a perfect fit, and my CAT is full length -- not trimmed by the engineers at Midas?
Here is the parts diagram http://volvopartslisle.com/assembly/73477097/1997-Volvo-850/Exhaust-System
- Year and Model: Many Volvos
- Been thanked: 76 times
I don't have any experience with Starla but if the pipe to the flanged connector post cat is unmolested it should bolt right up at the funky bubble joint. If you are buying new clamps for the cat to muffler pipe junction (highly suggested) be advised that the Volvo part number is for each half, not the set. That one set me back a few days. They are identical part numbers for each half.
xHeart
Thanks Lee!Ozark Lee wrote:I don't have any experience with Starla but if the pipe to the flanged connector post cat is unmolested it should bolt right up at the funky bubble joint. If you are buying new clamps for the cat to muffler pipe junction (highly suggested) be advised that the Volvo part number is for each half, not the set. That one set me back a few days. They are identical part numbers for each half.
Ordered parts from partsgeek - muffler W0133-1660568 http://www.partsgeek.com/catalog/1997/volvo/850/exhaust/muffler.html, and clamp W0133-1660565 http://www.partsgeek.com/catalog/1997/volvo/850/exhaust/exhaust_clamp.html.
The picture below from february repair shows CAT at right -- would it work?
- 11 Replies
- 5530 Views
Last post by 850oldschool
- 1949 Views
Last post by vtl
- 942 Views
Last post by TerrDawg
- 20 Replies
- 8394 Views
Last post by Klausc
- 2258 Views
Last post by matthew1
