My 96 850 GLT has given em its first check engine engine light in the 4.5 years I've owned it. (Started at 168k, now at 221k)
The code is a P0172. So i'll be looking for a vacuum leak.
I'll try the cigar method.
My question is can I just attach a hose to one the the extra connection on the vacuum tree? or is there better location.
I checked the vacuum connection on the left side of the manifold. It seemed ok.
-os
1996 850 GLT Need to find vacuum leak >> found
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- misha
- Has thanked: 155 times
- Been thanked: 432 times
P0172 is usually an elbow at the left side of the manifold(vacuum line),but can also be:
-fuel pressure regulator (vacuum side of the line)
-fuel injector's o ring(s)
...rarely but happens.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I took a look at the elbow from the left side of the engine and could see a crack where the elbow fits into the manifold. The other end of the elbow is connected to a larger piece of tubing.
Is this the correct replacement?
http://www.fcpeuro.com/products/volvo-v ... -9155862oe
or
http://www.fcpeuro.com/products/volvo-v ... ng-1389574
-os
or
-os
2021 Honda Pilot
2021 Honda Pilot
- Has thanked: 311 times
- Been thanked: 817 times
If the elbow is cracked then the PCV tubing may be deteriorating in general. The car may need a PCV servicing and a quick look at all of the vacuum lines.
I think it is the large-small elbow but I wouldn't buy it. Your best bet is to just walk into any auto parts store and get 3 or 4 feet of rubber, 5/16 vacuum line. It will be cheap. Run a fresh piece of line from that nipple in your photo over to where the existing hose connects to the flame trap housing, next to the throttle body. Choose any route you like, under the manifold or around the front. The vac line will last longer, be easier to install, and work better than the thin, hard plastic tubing that is in there now. Just leave the old hose in there.
Thanks, I was thinking of doing that see as it was probably going to be a PITA to get the elbow into the larger tubing. But I was going to look for the other connection on the vacuum tree.
The other connection is located by down by the flame trap, or is the vacuum tree considered part of the flame trap housing?
-os
-os
2021 Honda Pilot
2021 Honda Pilot
- misha
No, it's independent part.osmium wrote:...is the vacuum tree considered part of the flame trap housing?...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha wrote:No, it's independent part.osmium wrote:...is the vacuum tree considered part of the flame trap housing?...
So, If i am going to reroute the vacuum line, one end goes from the connection on the left side of the manifold; the other to a connection near the flame trap.
-os
2021 Honda Pilot
2021 Honda Pilot
- misha
The other end goes to the nipple on the flame trap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Great, thanks!misha wrote:The other end goes to the nipple on the flame trap.
I would have wasted a lot of time trying to figure which connection it was on the tree.
Probably toss the flame trap while I'm done there.
-os
2021 Honda Pilot
2021 Honda Pilot
