Hi,
Before repl ETA, I would get a lot of the Reduced Engine performance + Eninge System Service Rqd msgs....when I did get these, I would turn car off & restart.
This would make these msgs stop for varying periods of time (ie: longer periods initially, but much shorter periods finally). Anyway, towards the end, I was turning off/restarting many times in a trip (10, 20, even 30 times in a trip). Just two days ago, this process ceased to work at all and I had to limp home; where I finally repl ETA.
Occasionally, when going thru these "turn off/restart" exercises, I would get the ABS/Antiskid messages. These messages did not persist, but went away.
Well now that I have repl ETA, the ABS/Anti-Skid msg has returned today and has stayed on thru several drive cycles.
When repl the ETA, I had disconnected the battery...could a undercharged battery be the culprit?
I appreciate any help you could offer.
Thanks
Peter
05 S80 - ABS/Antiskid msgs few before ETA - persistent after
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Often times an ABS fault code is caused by nothing more than one or more dirty sensors in the wheel hubs. If you remove the wheel you can follow the wire to the sensor. There you will find a small screw or bolt that holds the sensor in the hub. Remove the sensor from the hub, clean off the business end of it, and reinstall it. This may not be your problem but it doesn't cost anything to try it.
seminolejack
- Year and Model: s80 2004
Peter,
I have the same sequence of error messages: 1. ABS/Anti skid service - 2.Reduced engine performance
Car enters limp mode and can be reset with ignition start-up. I'd like to verify that the problem is not electrical/connectivity before I replace parts.
My indie mechanic says problem is the the ETM/MAF structure but cannot access software to replace parts.
Jack
Jack
- 1498 Views
Last post by Ozark Lee
- 2646 Views
Last post by Mike Langlois
- 9 Replies
- 4754 Views
Last post by gilbeynut
- 10 Replies
- 3700 Views
Last post by SuperHerman
- 12284 Views
Last post by ggleavitt
