1998 V70 GLT Exhaust Rattle
I have the IPD turbo back exhaust and it started off quiet. However, as time goes on I get more and more rattle, this is over about a year. It's really only at idle or very low speeds. In gear or not doesn't change it other than when going from engaged or not and back there is a moment of silence. I'm thinking motor mounts but they look fine. No idea how old they are. I've checked the V-bands and they are all tight. Any thought?
- Year and Model: Many Volvos
- Been thanked: 76 times
Check the heat shields that are above the catalytic converter and the muffler. There is also a heat shield on the downpipe from the turbo to the catalytic converter on my XC but I'm not sure if the FWD versions have that shield or not.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Hopefully the heat shields. Mine turned out to be the insides of the cat coming apart. Had a used cat welded in place and all's quite now. Turbo back. Does that have a new CAT too? For checking the heat shields I had my car running and using welders gloves sort of felt around all over to see if I could make the rattle stop. Careful, it gets pretty hot.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- 1072 Views
Last post by thefisch
- 1108 Views
Last post by benpineapple
- 11 Replies
- 2021 Views
- 11 Replies
- 7669 Views
Last post by Sufbug
- 770 Views
Last post by 98v70dad
