Hi There,
Buddy of mine picked up a S70 T5 1999 model, it was at a shop where the old owner had given up putting money into it, they claimed it had "thrown a rod" the timing marks were all spot on to the exact tooth, there was spark also, so decided to do a compression test. It was a rented one from oreileys but it gave the following.
Cyl 1 = 40 PSI
Cyl 2 = 0 PSI
Cyl 3 = 60 PSI
Cyl 4 = 0 PSI
Cyl 5 = 40 PSI
I left the guage on and it didnt leak down at all which is odd however I know those numbers are way down (not forgetting I don't know the quality of the test kit)
So decided to pull the head off, everything looks straight, no bent valves and there freely moving before hand.
So My question to the world is:
1 - We are going to have a buddy of a buddy look over the head (head specailist) and see he notices something I cant see.
2 - Could it be pisting rings, I dont see any damage to the cyl walls, there's carbon on the pistons but nothing that looks bad, head gasket did have some water/coolant on the gasket itself, allthough the actual part looks good.
So if it was the gasket it could at least explain the lost of compression..
Any ideas?
No Compression on 2 and 4
moosemanusa
- Year and Model: Different Vol's
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Probably overheated - I wouldn't be surprised if the head is warped slightly.
'98 S70 T5
2016 Chevy Cruze Premier
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
No visibly burned exhaust valves?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
moosemanusa
They are very black, along with the top of the pistons, I've never gone this far into an engine before so not sure what to expect.
- 1737 Views
Last post by Livens
- 26 Replies
- 4384 Views
Last post by momentumbob
- 3979 Views
Last post by Jraptor2000
- 17 Replies
- 4250 Views
- 156 Views
Last post by gowriprasanth
