electronics on radiator
Tylerberg45
Year and Model: 1998 s70
Post by Tylerberg45 »
1998 Volvo s70 t5. What is the little pump thing on the driver aide of the radiator for? And what lines plug into it? I can't seem to find a diagram. Also the secondary air pump under the battery tray. What line connects to that?
mfagus
Year and Model: 1995 850 Turbo wagon
Post by mfagus »
on my 95 850 turbo wagon under the battery tray is the cruise control
not sure about the other item you asked about.
Mark
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
SAS pump has a line to the airbox and another line to the silver canister at the exhaust manifold at the back of the engine.
Cruise control pump is under the battery, is that what you mean?
'98 S70 T5
2016 Chevy Cruze Premier
Has thanked: 1613 times
Been thanked: 4075 times
Could it be the EVAP purge valve you seek?
One electrical connector, two hose nipples.
Tylerberg45
Cruise control makes sense considering it doesn't work. ill worry about this later. I'm currently in the middle of a motor swap and failed to take pictures of where stuff is supposed to go. It runs perfectly but seems to be a little low on power and is getting bad gas mileage. Its possible that its the purge valve.. It is a pump of some sort it moves air and is mounted at an angle on the fan shroud. Idk what lines are supposed to be connected to it.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It sounds like you are describing the purge valve but snap a picture of the area in question and post it back.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Is it black plastic or a metal part?
If it's plastic...it's what Lee said.If it's metal...it is part of SAS system.Both have electrical connectors.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Tylerberg45
Ok. I am posting the requests for pictures along with all of my other questions for hoses, electrical connectors and what not. hope this helps!
Pump on radiator
Pump on radiator
Is this the correct hose to connect to the pump thing? Whats the filter for?
Where does this hose connect to? I thought it was egr but can't find a spot for the opposite end of the hose. also the vacuum line on the thing i'm pointing at is non exsistent
Random port on air box lid
What does this connect to? doesn't seem to have any vacuum or coolant going through it. There is a plug on the end of it that i put just for kicks and giggles
This looks like EGR gear to me, but Im not an expert on that - 1999 doesn't have of course.
jblackburn
#1 attaches to the vacuum tree area at intake manifold. That is vacuum for the fuel pressure regulator.
#2 attaches to the output of the SAS air pump (under the battery tray)
#3 is the input for the SAS air pump.
#4 ??????????
#5 - attaches to the radiator bracket, you can actually see the mount on the left hand side of your picture. That is the EVAP purge valve, not a pump.
'98 S70 T5
