P80 Idle Control slide or IAC 9454745 Cleaning
P80 Idle Air Control (IAC) Cleaning
CTHarris88
- Year and Model: 1996 850 GLT
So i swapped out my MAF with an extra my uncle had lying around. ( he has three volvo's including an 850 wagon same year as mine. Seemed a little better but not by much. He looked sort of behind the the power steering fluid pump and there was a little hose that seemed to go into the intake manifold on the passenger side. (im assuming this is the hose someone mentioned before maybe 3 inches long give or take. ) I honestly didnt see this when i was looking for it, that because there is barely anything left to it. The two ends were pretty much all that was left. He wasnt sure what the hose was called so I figured I'd ask here so i can find out what it is i need and go get one. Also someone mentioned that if its really bad I may ne a PCV job? I'm no rocket scientist but im pretty sure 75% of the hose qualifies as rotted or brittle.
- Has thanked: 311 times
- Been thanked: 817 times
Yeah that is why I said drive it around - it doesn't sound like replacing the MAF will do you any good, more likely it is that vacuum hose we talked about. That hose is part of the PCV system, which almost certainly needs servicing. The hose in question runs from the end of the intake manifold back to the flame trap.
Matthew1 posted a good solution for when that hose rots out. Do some searching, you will find his thread, you can do that repair for now to get it back on the road for low cost. Then start reading up on PCV repair.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Can someone explain what rotates on the IAC? JReed mentions twisting the IAC in your hand and making sure the plate rotates freely. I have a spare IAC and I don't see any possible way of twisting it and getting anything to spin.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Good question! If you twist the body of the IAC briskly in your hand, the internal baffle plate will rotate as well. When the passages are nice and clean, the plate will rotate easily without sticking or hanging up.
polskamafia mjl
Thanks! That makes perfect sense now.
- 10 Replies
- 1811 Views
- 849 Views
Last post by a73s
- 668 Views
Last post by turtle1615
- 1585 Views
Last post by Volvo Manic
- 993 Views
Last post by misha
