I have a 2000 S40 w/116K miles. I did a compression test a month or so ago after I had a bad engine coil that set off a misfire code for cylinder 2 (which was then replaced). I ended up replacing all spark plugs and cylinder 2's had a little bit of oil on it. I did the compression test and cylinder 1 registered at 130 (the others were 150). Added a bit of oil and cylinder 1 went up to 150. Any idea what could be causing the issue with cylinder 1? I currently don't have any misfires, but I'm wondering if this is something that could lead to big problems later or not.
I'm wondering if a partially-clogged PCV system could cause any of these issues. Otherwise, I guess I need to find a shop with an endoscope that they could put down into the cylinder to tell me for sure.
2000 S40 Compression test shows low pressure
jose456891
- Year and Model: 850 GLT 2.4 1996
Worn rings.
When you add oil the film creates a seal around the piston. So if the compression jumped from 130 --> 150psi, you have worn rings.
No biggie, just remember that frequent and timely oil changes reduce the stress on your engine.
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
When the engine is running at normal hot temperature and oil is circulating properly the 20 psi discrepancy may be less than what your readings indicate cold.
I would just leave it be for now and monitor the oil consumption, with proper oil change schedule as jose456891 has stated.
Perhaps use 10w30 assuming your using 5w30 currently. (synthetic)
- 1777 Views
Last post by Livens
- 10 Replies
- 1898 Views
- 812 Views
Last post by FLXC90
- 1111 Views
Last post by Sommerfeldt
- 10 Replies
- 1864 Views
