While I'm waiting for my O2 sensor, timing belt, and coolant temp sensor to get here I've been doing standard spring cleaning and bulb replacement etc. etc...
My brother has a 93 850 and it has a key fob system.. for whatever reason he has decided he doesn't want to keep it or even get another one but my father gave me the option to take what I want from the car before he either scraps it or sells it.
My car doesn't have the black box behind the glove box and I was wondering if I could just take the unit out of his car and bolt it into mine?
And while I'm at it
Is there anything else worth keeping? I would obviously check the quality before hanging onto it.
Thanks
Nick
97 850 Key fob install and stuff to keep
dairyqueen814
- Year and Model: 1997 855 NA
1994 850 Sedan NA Black, 343,000mi - Crashed and parted
1993 850 Sedan NA Red, 240,000mi - Now my little brother's car
1994 850 Wagon NA White, 251,222mi - Sold
1997 850 Wagon NA Red, 105,000mi - Currently my pride and joy
- Has thanked: 292 times
- Been thanked: 765 times
As long as the 93 black box is compatible with your 97, switching the unit over should do it. Certainly if you swap over the black box from a later year car it will work, I've done that myself, I just don't know if the 93 technology/system was different. You may have to go through the programming again.
Blower motor is worth grabbing while you are in there, overall there are a ton of parts that are the same and are worth keeping.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
dairyqueen814
If it's getting scrapped Ill hold on to some of the relays and the wheels to put snows on for sure
maybe the grille just for fun
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I don't think that key fob system will work. If your car had it, your box is on top of the cluster I think.
Sun visors, shift knob, I like those control arms, speakers, dash pad, ...
