Well guys I've been busy on my 850 glt. New transmission, new pcv valve kit and a new radiator all done at the same time this spring.
I need some idea's as to why the radiator cap now leaks badly under pressure. When I run the car with out the cap on it bubbles and spurts anti freeze out of the coolant box, then the fan kicks on and all of my anti-freeze is gone out of the coolant box. The fan turns off and out comes all the anti-freeze I poured in when the fan turned on.
Or maybe I'm not filling the system correctly or ? I need a new cap
1997 850 glt leaking radiator cap
ezliving4ume
- Year and Model: 850 glt, 1997
No smoke out the tail pipe, no water in the oil and no oil in the water. Wouldn't that rule out a bad head gasket?
I was just told by a co-worker that the heat must be on and the fan must be on in order to correctly fill the coolant system, yes, no maybe?
tryingbe
- Year and Model: None
- Been thanked: 26 times
Change the radiator cap. The coolant system is suppose to be pressurized to 12-16psi, without the cap, the coolant is going to boil and get it.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
ezliving4ume
i have a new cap in my hands now!
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Usually yes but not always.ezliving4ume wrote:No smoke out the tail pipe, no water in the oil and no oil in the water. Wouldn't that rule out a bad head gasket?
Yes.ezliving4ume wrote:I was just told by a co-worker that the heat must be on and the fan must be on in order to correctly fill the coolant system, yes, no maybe?
- Year and Model: Many Volvos
- Been thanked: 76 times
If you had a gray colored cap they all tend to crack and leak. Replace it with one of the blueish green caps and it will then last pretty much forever.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
_
May have air in the system as you indicated a new Radiator. There could be possibility of a bad Expansion Tank also. They warp as they get old and the Cap will not seal well. This was the case for my car. A new Tank took care of the constant seepage around the Cap.
_
_
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You should never run these cars with the coolant reservoir cap off. The system is designed to run under pressure. You fill the system when the car is cold.
Had gasket leaks actually have 3 options; oil in coolant, coolant in oil and combustion air in coolant (no fluid mixing).
If you have the "proper" thermostat with the bleeder pin in it, these systems fill very well. As you add coolant to the bottle, air bleeds through that pin and the system almost fills totally up. Drive a day and top it off the next day, maybe about 18 oz.
- rspi
Contact rspi..
Go to 5:45 in this video.
- 13 Replies
- 2763 Views
Last post by bmdubya1198
- 18 Replies
- 3904 Views
Last post by TheMrFailz
- 6318 Views
Last post by erikv11
- 12528 Views
Last post by Vova585
- 18 Replies
- 11425 Views
