Like the title says my 1991 Volvo 740's crankshaft pulley come unbolted while driving.
What puzzles me most is seconds after it come off the Volvo would not fire up.
It was not driven far after it come off, maybe a couple of blocks.
What might be the cause of the not starting? Battery seems fine, not driven without the belt long enough to discharge.
Called tow truck now it sits at mechanics shop.
Also to reinstall the pulley what approximately might the cost be?
Thank you for any help...much appreciated.
Gary
1991 Volvo 740 crankshaft pulley falls off while driving
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
What does the engine do when you try to start it?
Did the crank gear walk itself off the crankshaft somehow when you shut the car down?
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
gbm97
- Year and Model: 1991 volvo 740
Minutes after starting and driving less than 1 mile all idiot lights come on & lost power steering. Kept driving in a fight to return home. The final stall come the second I put on turn signal. Opened hood and laying in pan was belts pulley bolt and thick washer. When turning key it was a no start with no signs of firing. Sounded different than the usual start. Hard to explain, kinda like a near dead battery but still turning over hard enough which under normal circumstances would likely start it.
