Side Marker Light Installation DIY
Side Markers Your Volvo Always Wanted
jrobles007
- Year and Model: 850 NA, 1994
Some of the other posts I read had the wiring running through the tire side. There is a gap between the plastic fender liner (not sure if that's what's called) and the fender itself, should help in protecting the wire. They removed the front signal light to fish the wire through and splice into the signal light wiring. The light is easy to remove. There is a spring with a ring end that you remove first and then carefully pull the light out. A screw driver may help in releasing the tension. Check out this YouTube video: http://m.youtube.com/watch?v=844fa1T5DWgHope this helps.
JR
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Thanks, but the YouTube video is for a completely different light -- the corner parking light. It has nothing to do with side markers.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2858 times
- Been thanked: 1332 times
My 850 has the grommet, but no wiring or connector in itjrobles007 wrote:On my base 94 850 I found that it was already wired to accept the side markers. The wiring is held in place by a grommet probably to keep it from rattling.
- E Showell
My '98 V70 -- base model -- has the grommet, but no wires or connector. I'm betting the base trim level is the kicker.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Guess-- sure. If it is a base model, I'll say no.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
We're talking about the same thing. I'll be installing side marker lights wired into the directional so that they are essentially side directionals. I do not intend to wire them into the parking light circuit. The prewiring is for side directionals. It does not exist in my car.
'95 855 auto (sold)
'95 855 auto (sold)
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
(1994 855T) I got the side markers,but I can't see if there is any wiring up in there. Is it just dangling, or is it tied back? If I pull the turn signal housing , can I find the other end of the side marker wiring from up front?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
