Side Marker Light Installation DIY
This topic is in the MVS Volvo Repair Database » Side Markers Your Volvo Always Wanted
jrobles007
Year and Model: 850 NA, 1994
Re: Side Marker Light Installation DIY
Post by jrobles007 »
Some of the other posts I read had the wiring running through the tire side. There is a gap between the plastic fender liner (not sure if that's what's called) and the fender itself, should help in protecting the wire. They removed the front signal light to fish the wire through and splice into the signal light wiring. The light is easy to remove. There is a spring with a ring end that you remove first and then carefully pull the light out. A screw driver may help in releasing the tension. Check out this YouTube video: http://m.youtube.com/watch?v=844fa1T5DWgHope this helps.
JR
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Thanks, but the YouTube video is for a completely different light -- the corner parking light. It has nothing to do with side markers.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
jrobles007 wrote:On my base 94 850 I found that it was already wired to accept the side markers. The wiring is held in place by a grommet probably to keep it from rattling.
My 850 has the grommet, but no wiring or connector in it :-(. Some 850s were pre-wired, some weren't. One day we'll crack the mystery. So far, we know the likelihood doesn't follow model years. Perhaps it was triggered by a trim option.
Also -> Amazon link
E Showell
Post by E Showell »
My '98 V70 -- base model -- has the grommet, but no wires or connector. I'm betting the base trim level is the kicker.
'95 855 auto (sold)
epukerob
Year and Model: C70 1999, S80 2003
Post by epukerob »
Any guess whether a '98 C70 would be pre-wired??
E Showell
Post by E Showell »
Guess-- sure. If it is a base model, I'll say no.
'95 855 auto (sold)
NoralfB
Year and Model: V70, 1997
Post by NoralfB »
I think the pre-wiring is meant for side directional indicator blinkers. At least that's how they are set up in Europe. I have only seen that use for this lamp.
E Showell
Post by E Showell »
We're talking about the same thing. I'll be installing side marker lights wired into the directional so that they are essentially side directionals. I do not intend to wire them into the parking light circuit. The prewiring is for side directionals. It does not exist in my car.
'95 855 auto (sold)
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
(1994 855T) I got the side markers,but I can't see if there is any wiring up in there. Is it just dangling, or is it tied back? If I pull the turn signal housing , can I find the other end of the side marker wiring from up front?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
On my Daughters 94 850 there is no wires for a side marker light.
