Build your own TCV, save 50%
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Volvo Repair Database Build your own TCV, save 50%
Post by matthew1 »
All hail Brett Borders for this info!
Everything
MAC Boost Control Solenoid Valve BCS MAC 35A-AAA-DDBA-1BA
$25.95 New in eBay Motors, Parts & Accessories, Car & Truck Parts
http://www.ebay.com/itm/261433744015?ss ... 1439.l2649
10 Pieces, 1/4" Hose Barb x 1/8 NPT Brass Fittings
http://www.ebay.com/itm/131056710293?ss ... 439.l2649w
$11.00 New in Business & Industrial, Construction, Building Materials & Supplies
VOLVO PARTS - TERMINALS 978299 X 2 $4
BOOT INSULATOR 967340 $3
PLUG 979153 $4
Also -> Amazon link
epukerob
Year and Model: C70 1999, S80 2003
Post by epukerob »
Where do you get that nifty blue (silicone ?) rubber hose??
matthew1
Site Admin
Post by matthew1 »
Also -> Amazon link
configsys
Year and Model: V70R
Has thanked: 2 times
Been thanked: 5 times
Post by configsys »
I'm sold. This is awesome. Thanks!
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
Acknar
Year and Model: 940, 1993
Post by Acknar »
Finally got one of my own build up. Got the connector from a older 240 o2 sensor found up on the firewall on the pass side. Hope to get it installed tomorrow. Crimped the connections and used hot melt heat shrink to make it waterproof.
cjep
Year and Model: 1998 C70 HPT
Post by cjep »
In case anyone is wondering, the hose routing of this model is exactly the opposite of the IPD HD TCV. It should be connected:
Port 2 - compressor
Port 1 - wastegate
Port 3 - fresh air (or block it off like I did)
You will kill your engine if you get them mixed up, so to be safe blow through the sides ports - the side you can blow through should be connected to the compressor, the other side to the wastegate. Basically, without power, the TCV should supply the compressor pressure to the wastegate.
Good luck!
1998 C70 HPT - Saffran - Auto - 150,000 km
If you are in Brisbane, Australia, PM me. I would love to meet other volvo enthusiasts!
rx7850
Year and Model: 1996 R Wagon
Post by rx7850 »
Thanks for taking the time to do this great DIY.
db130
Year and Model: 2002 V70 T5
Post by db130 »
Are you sure about that? I used the same MAC solenoid back in 2010 for a 98 S70 T5 and I used:
Port 1 - fresh air
Port 2 - wastegate
Port 3 - compressor
Here's a Volvospeed thread where a guy used the same solenoid on his 2007 V70r
He appears to be using Port 1 as fresh air(evidenced by the blue dot on the hose)
Here's another URL using the mac solenoid for an internal wastegate turbo
cjep wrote:In case anyone is wondering, the hose routing of this model is exactly the opposite of the IPD HD TCV. It should be connected:
Port 2 - compressor
Port 1 - wastegate
Good luck!
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
My 2001 T5 with 231,000kms (new plugs) has a hesitation/go hesitation/go attitude at light throttle/steady speeds. It feels like a headwind at times.
On full throttle it seems to go like the clappers. No codes of course!!
Feels like boost/no boost but hard to tell. Is this where a failing/old TCV will begin to show these signs?
Ended up being a failed O2 sensor. Keeping up with a 17 yr old car's maintenance can be challenging......
In the meantime I just received my MAC valve.
