98 C70 2.3L Poor running MVSUCCESS bad MAF
Ran like a CHAMP, then all of a sudden. Codes P0300/0301/0303/0304 - multiple cyl misfire. Plugs/wires/cap/rotor all checked. All wires read 600~1100 ohms (IPD cool-blue set). These ignition parts are all 1~yr new. Coil is ~ 0.5-ohm on primary; 8700-ohm secondary (terminal to ground is OPEN, term to either primary terminal reads 8700-ohm). Crank pos sensor reads a consistent 280~ohm, fluctuating only a few ohms as I crank the engine (Is this proper? The Fluke digital can't really see quick fluctuations). Unplug cam sensor and engine won't start at all. I sometimes smell raw fuel - seems to confirm she ain't far'n right. When running, I listen to all injectors w/ the stethoscope and they all do the clicky-clacky loud-'n'-clear. Off now to get adapter to check fuel pressure - but if that is good ... ???
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
You can also check pressure with a pencil type air gauge, probably ruins it for air but it's only a buck. Got a spare 103 relay for the fuel pump? You are probably going in the right direction with the cam sensor though. Won't run without the cam sensor and cranking like that will give you a gas smell and rinse off the oil on the cylinder walls. Any sudden dampness, heavy rain, big puddle?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
No rain or wetness - I am in So. Cal. paradise ... it has been dry as a bone. Finding adapter for that tire stem/Schrader valve is like chasing a rat hole; I have cheapo tire gage and will do that rat-now... I'll see about F/P relay...
rmmagow
Check at the bottom on the intercooler, that's where mine came loose. Really give it a good yank, not just a look as it can look fine.
- Has thanked: 1505 times
- Been thanked: 3817 times
MAF replacement next. New part, Bosch only. Lots of junk out there at 1/3 price that work well as bookends
Ok... BOSCH replacement - good, clean, used part. Exact duplicate. Rec'd in 2 days from Texas (to Callie) e-bay with 14-day money back gaur. Installed in 5 mins. - everything else already put back together; I am thinking "success oriented project". Fired right up and HAULS ASS! We are good to go... hopefully I can help others now w/ similar trouble. BTW - here is a fitting to attach to the fuel rail for pressure check: http://www.skygeek.com/ats-556.html
- 32 Replies
- 5235 Views
- 2819 Views
Last post by itsmekirby
