I've been working on removing the gear shift knob of my car so I can install a new gear shift boot. I know it can be removed without destroying it. I don't feel like paying for another knob (volvo's fix is to cut it off).
I'm at an impasse. I'm open to to suggestions as to how to remove it.
Here are some pics.
I shined a light up inside so people can see what it looks like internally. I think if I can spread those pieces of plastic I can take it off, but I'm not sure to be honest.
A tool I was using, it's not long enough because to move past the trapezoidal base.
The only reference I found on this forum the person cut the entire thing off.
I found this, but it was only moderately helpful, especially because some of the text between the images makes NO sense.
http://volvoforums.com/forum/volvo-850- ... ics-51244/
https://www.matthewsvolvosite.com/forums ... =1&t=32886
These are the only 2 threads I have found after hours and hours of searching.
Thanks in advance.
1995 850GLT Manual Removing Gear Shift w/out destroying..
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Any clues?
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Well, according to the VolvoForums link you posted, a short length of pipe, cut in half will release the shift knob. The tool you were trying to use looks like it would accomplish the same thing if it were long enough. Why not try the pipe method??
viper69
No that is wrong. He used the pipe to remove only the rubber boot below the gear shift knob.polskamafia mjl wrote:Well, according to the VolvoForums link you posted, a short length of pipe, cut in half will release the shift knob. The tool you were trying to use looks like it would accomplish the same thing if it were long enough. Why not try the pipe method??
Volvo 850 GLT 1995
jeffsws
- Year and Model: 850 NA 1997
- Has thanked: 3 times
- Been thanked: 3 times
Hate to bump an old thread but I'm curious if you manged to remove the gear shift? I am in a similar boat myself now. So it's not possible to install a new boot without remove the gear head?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
My brother seems to be an expert on this. It takes strong hands. You squeeze the plastic clips at the bottom while pulling straight up with both hands. It comes off pretty hard so don't smash the sunroof with your hands. That's how it works on the 99 S and V70s. Can't say if it is the same for the '95 850s.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
viper69
Sorry for replying so late. I did manage to remove the gear shift. You cannot install a new boot without removing the gear shift knob. I did not destroy my gear shifter as Volvo recommends. I bought a tool on the internet that someone made specifically for this purpose. It worked perfectly.jeffsws wrote:Hate to bump an old thread but I'm curious if you manged to remove the gear shift? I am in a similar boat myself now. So it's not possible to install a new boot without remove the gear head?
Volvo 850 GLT 1995
viper69
It is the same for my vehicle. HOWEVER, I used a tool for this, and didn't have to worry about the above. The gear shift is on their like cement as a result of the clips. It's over engineered!E Showell wrote:My brother seems to be an expert on this. It takes strong hands. You squeeze the plastic clips at the bottom while pulling straight up with both hands. It comes off pretty hard so don't smash the sunroof with your hands. That's how it works on the 99 S and V70s. Can't say if it is the same for the '95 850s.
Volvo 850 GLT 1995
tryingbe
- Year and Model: None
- Been thanked: 26 times
After I cut off the old shift knob on my 94-95 shifter, I determined there was no way I could have got the knob off in one piece. The rubber was molded to the metal.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I used three small finish nails and a zip tie. It worked.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 653 Views
Last post by wool
- 7796 Views
Last post by oragex
- 1698 Views
Last post by Legofan
- 953 Views
Last post by Volvofan94
- 784 Views
Last post by 1ezliving4ume
