How to Replace Front CV Axles - 2000 V70XC
Where to Get A Rebuilt Axle
Re: How to Replace Front CV Axles - 2000 V70XC
on the outer end of the big part of the axle. what is that big ring gear that appears to have no physical contact with anything else? because when i was replacing my wheel hub assembly i noticed that mine was cracked in half and longer fully seated on the shaft. I am worried that this will turn into a more expensive fix. please help. thank you.
- Year and Model: Many Volvos
- Been thanked: 75 times
The thing that looks like a gear is the reluctance ring for the ABS. In needs to be properly seated and it needs to completely encompass the outer part of the CV joint. If it has slipped out of position you might be able to glue it back in place but I'm not sure what kind of glue to use.
If it has broken and no longer encompasses the entire circumference of the end of the axle then you really have no choice but to replace the axle or you will have constant ABS problems.
The ring isn't important mechanically, it just triggers the ABS wheel sensor.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Bumping this post.
Do I have to use a new axle nut/bolt or it's ok to put back the original one? It's the small one for 2003+ cars.
Volvo wants you to change the bolt but since it isn't angle torqued on the later models I just used some Loctite Red and reused them. My rule is that if the bolt gets angle torqued it gets replaced, if not it gets re-used.
- oragex
Great, thanks.Ozark Lee wrote:Volvo wants you to change the bolt but since it isn't angle torqued on the later models I just used some Loctite Red and reused them. My rule is that if the bolt gets angle torqued it gets replaced, if not it gets re-used.
Thanks to all of the above I was able to remove and replace the passenger side axle on my '07 C70. However, at low speed there is a high pitch noise that I suspect comes from the carrier bearing. I did apply grease to the bearing before installing the axle. I also suspect the squeal is coming from the side of the bearing as it rubs against the inside of the bracket. Is that likely?
Any thoughts on how to stop the squeal?
The way the carrier is made it shouldn't be able to contact the rotating part of the bearing at all. It should clamp around the outer race on the bearing and hold it stationary. Did the carrier bearing cap fully mate to the other side of the carrier bearing flange when you tightened the cap back down? If not, it is possible that the axle isn't fully seated into the transmission.
- Has thanked: 1502 times
- Been thanked: 3817 times
You have to give it a good pop to get it out, I use a pry bar and wood against the transmission case.
I was in your country in the 80s, crazy time. Great people. Don't get confused with Nambia, though.
- 587 Views
Last post by jmartin919
- 15 Replies
- 4607 Views
Last post by zanzabar
