Did you know? 🤔
1995 850 t5-R
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
polskamafia mjl
Has thanked: 7 times
Been thanked: 6 times
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Mar 31, 2014 10:12 pm
March 31, 2014 - 218,XXXmiles
Headliner Re-installed
- Some trim pieces not installed yet
Sunroof shade material replaced
Driver and passenger seat power recline cables adjusted
Vacuumed and shampooed carpet and floor mats
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Thu Apr 03, 2014 7:33 pm
April 3, 2014 - 218,223miles
OEM Volvo battery installed (520CCA, 60AH which is less than the 600CCA in the other battery :? )
Sun visors re-installed and wired
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Apr 07, 2014 7:26 pm
April 6, 2014 - 218,XXXmiles
Sun visor wiring soldered
A-pillar and rear trim pieces installed
New rear view mirror painted and installed
Sunroof trim and dome light still need to go back in
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Apr 14, 2014 6:43 pm
April 14, 2014 - 218,800miles
Blacked out grill
Replaced hood release lever behind grill
Installed dome light but no interior lights are working at this point so I took the dome light back out. I'll have to diagnose the problem before I can finish re-installing the interior.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Thu May 01, 2014 6:47 pm
May 1, 2014 - 219,253,miles
Removed front bumper to repaint and repair cracked plastic.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Sat May 03, 2014 3:04 pm
May 3, 2014 - 219,281miles
Painted front bumper trim
Secured broken plastic with metal brackets and bolts using rspi's method (
Removed rear bumper
Painted passenger side exterior door trim
I noticed the driver side bracket for the rear bumper is completely destroyed by rust. The passenger side doesn't look too bad. The part number for the brackets is 6816114 and I found several sources online. According to rspi Volvo no longer sells them.
Last edited by polskamafia mjl on Sun May 04, 2014 5:48 pm, edited 1 time in total.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Sun May 04, 2014 5:47 pm
May 4, 2014 - 219,311miles
Painted driver side exterior door trim
Inspected air filter (installed May 3, 2013)
Last edited by polskamafia mjl on Mon May 05, 2014 4:31 pm, edited 1 time in total.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon May 05, 2014 4:26 pm
May 5, 2014 - 219,311miles
Removed as much rust as possible from rear bumper brackets and impact beam.
Painted all rust-prone surfaces with Rust-Oleum Spray Paint to prevent more rust.
Re-installed rear bumper.
Repaired cracked plastic on front bumper with epoxy.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon May 12, 2014 7:14 pm
May 12, 2014 - 219,469miles
Removed driver and passenger side roof trim
Stripped and sanded the metals rails, ready for paint
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Wed May 14, 2014 7:11 pm
May 14, 2014 - 219,528miles
Painted and re-installed roof trim
