1995 850 t5-R
Forum rules
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Re: 1995 850 t5-R
March 31, 2014 - 218,XXXmiles
Headliner Re-installed
- Some trim pieces not installed yet
Sunroof shade material replaced
Driver and passenger seat power recline cables adjusted
Vacuumed and shampooed carpet and floor mats
polskamafia mjl
April 3, 2014 - 218,223miles
OEM Volvo battery installed (520CCA, 60AH which is less than the 600CCA in the other battery
Sun visors re-installed and wired
polskamafia mjl
April 6, 2014 - 218,XXXmiles
Sun visor wiring soldered
A-pillar and rear trim pieces installed
New rear view mirror painted and installed
Sunroof trim and dome light still need to go back in
polskamafia mjl
April 14, 2014 - 218,800miles
Blacked out grill
Replaced hood release lever behind grill
Installed dome light but no interior lights are working at this point so I took the dome light back out. I'll have to diagnose the problem before I can finish re-installing the interior.
Blacked out grill
polskamafia mjl
May 1, 2014 - 219,253,miles
Removed front bumper to repaint and repair cracked plastic.
polskamafia mjl
May 3, 2014 - 219,281miles
Painted front bumper trim
Secured broken plastic with metal brackets and bolts using rspi's method (
Removed rear bumper
Painted passenger side exterior door trim
I noticed the driver side bracket for the rear bumper is completely destroyed by rust. The passenger side doesn't look too bad. The part number for the brackets is 6816114 and I found several sources online. According to rspi Volvo no longer sells them.
Removed rear bumper
polskamafia mjl
May 4, 2014 - 219,311miles
Painted driver side exterior door trim
Inspected air filter (installed May 3, 2013)
polskamafia mjl
May 5, 2014 - 219,311miles
Removed as much rust as possible from rear bumper brackets and impact beam.
Painted all rust-prone surfaces with Rust-Oleum Spray Paint to prevent more rust.
Re-installed rear bumper.
Repaired cracked plastic on front bumper with epoxy.
polskamafia mjl
May 12, 2014 - 219,469miles
Removed driver and passenger side roof trim
Stripped and sanded the metals rails, ready for paint
polskamafia mjl
May 14, 2014 - 219,528miles
Painted and re-installed roof trim
