2004 s60 a/c blower intermittently not working
babygirl7345
- Year and Model: s60 2004
my a/c blower for the most part doesn't work. It doesn't matter what setting, high, low, hot or cold. Randomly when i drive over a bump or turn a corner it will come on. I took the blower motor out and tested with the battery and it runs fine. Do I most likely need to replace my resistor or is it possible I have a short somewhere?
JRL
- Year and Model: Several
- Been thanked: 16 times
Blower/resistor are together on P2s...... replace
babygirl7345
Thank you, that's what I was thinking but wanted to be sure before I purchased a new blower motor.
moosemanusa
- Year and Model: Different Vol's
Does it do it on warm also? Sometimes it's the dial.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
My 2004 P2 with 200K miles was doing this (no blower at times and then a bump would make it start). The blower motor brushes were worn out. I took it out of car and it ran batt jumpered until I moved it around and then it quit. I installed a new one. I did an autopsy on the old one and the brushes were little nubs. Motor was full of brush dust. The motor is not made to be serviced.
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
If you want to replace the motor we have this "How to" on the subject.
https://www.matthewsvolvosite.com/forums ... =9&t=21343
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
babygirl7345
I purchased a replacement blower motor with module and it still doesn't work. I've been told to try replacing the ac control relay. Could this be my problem?
DGM
Verify/replace fuse (11C26) on the left hand side of your dashboard (30 Amps). It could be deformed or damaged. Check wiring and plug terminals. Measure battery voltage at the control unit (4/31) plug. Verify ground continuity from the plug to the chassis. The control unit regulates motor speed (6/28) based on the signal received by the CCM (3/112).
If you find nothing have the car scanned for codes ideally with Vida-Dice. You may have a condition that interfere with the CCM operation.
babygirl7345
Blower motor still intermittently not working no matter the setting, hot, cold, high, low and everything between. When it works, all functions work properly. When it isn't working it will randomly turn on after hitting a bump or turning a corner. Also something new I've noticed, the blower motor occasionally runs when the car is totally turned off and no keys in the ignition. Tried replacing the blower motor and resistor, checked fuses and had a mechanic test for power to motor and control panel. The mechanic couldn't be sure of the problem because the motor was working correct at the time. He said possibly the control panel is bad. I want to be sure that this is the problem because control panels, from what the mechanic said, are expensive.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There could be a short in a wire or a corroded connector under the dash - such as from water/coolant dipping. The blower should not have voltage without keys in ignition.
- 683 Views
Last post by Mojobaby27
- 715 Views
- 1134 Views
Last post by RickHaleParker
- 3030 Views
Last post by jlh3rd
- 1099 Views
Last post by volvomadness
