A Box of Throttle Bodies. 3 Inch Turbo Conversion.
Ben850
Been thanked: 7 times
Post by Ben850 »
osman wrote:I already have a NA intake manifold lying around and a 960 throttle/body plate is easily attainable. Seems like a nice addition to my T5 motor/turbo/ecu swap with white injectors. Instead of tapping a third intake manifold hole for the turbo vacuum, why not just use one of the throttle body "tree" options?
So Should I use the throttle body itself from the 960 or just the plate in a 850 TB on a 850NA intake Manifold, also have you done the NA cams mod?
No. The 960 throttle body has different positioning for the linkage, and TPS.
I used an N/A throttle body from a '94 850 that had no EGR or other vacuum attachments.
The only thing you have to do is direct a vacuum from the manifold to the turbo.
I did point that out in the other photo. I brought that vacuum fitting to a NAPA parts place near me to get a matching tap for that thread. It was a Saturday just before closing time, and I was so happy he had one. I believe the tap was $4. or so.
I drilled that hole, cut the threads, and the old vacuum fitting was put in the same place where the original piece was.
I believe that vacuum delivery is probably consistent when coming from within the plenum, as opposed to a tree that has other parasitic vacuum taps.
It is also an indication of boost.
There is likely a reason for that design. Also that little place on the N/A manifold for the fitting. Just in case we might figure out an interesting modification.
So after the very simple drill, and tap, (clean up shavings) That was that.
Oh, I have not done the cams. That is a can of worms where the flood gates of oil drips I do not want to open with the wagon , yet.
If I blow out a cam seal, or start to have leakage from the cam cover, I might go there.
In the mean time, I am afraid I may already have to be spending money for new front rubber, due to my lack of throttle pedal restraint.
It seems to be working well.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Is that a common problem with the NA cams mod? NA cams are on my list of mods while I swap in my M56 transmission.
Ben850
Post by Ben850 »
I'm not sure it is a problem if it is done carefully and correctly. I'm just saying I am not sure I even need to do that at this point.
There is only so much usable horsepower you can put to a front wheel drive.
Maybe later, if I get bored.
