DIY: Flaring your Brake Lines Topic is solved
steve850
Year and Model: XC70, 2004 and 2010
Been thanked: 3 times
Post by steve850 »
I know this is old, but Great chronicle! Just went through this myself, but had to cut the pipe back a few inches, so I bought a six inch piece of 3/16 euro-flare-ended pipe, cut one end off and flared a standard nut on it to make and extension, flared a std nut on the original pipe and put a union between them.
I would gladly have replaced the who pipe (driver's side, so only about 30 inches long) but the stealer want 78$ for it and the parts places only sell hard lines with the same connector at each end - and I can't find out what size the larger nut is on the ABS unit end.... If anybody should happen to know...?
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
Ben850
Been thanked: 7 times
Post by Ben850 »
I actually have all the flare tools from doing lines on my '92 Olds.
If/when I break the rear connections to the calipers on my wagon, I will replace the lines.
It is good to know how to use, and work the flaring tool. Not fun, and I am so over it.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Been thanked: 504 times
Post by cn90 »
I am just wondering (yes, just wondering) if anyone has done this technique for seized connection.
Assuming heat from a propane torch fails to undo the seized connections...
1. Loosen the C-clip to allow the whole assembly to go upward.
2. Slide the whole assembly upward.
3. Use a dremel with cutting wheel (wear goggles!) and SLOWLY cut through the hose's metal end.
Go SLOW and constantly check to be sure one does not damage the nut threads.
Once you get down to about 1mm to go, use a chisel or screwdriver and split the connection.
In other words, think like a surgeon operating and cut slowly.
Does this idea sound good? This idea (if it works), would prevent you from flaring the line etc.
steve850
Post by steve850 »
You probably could, but even if you did manage to not touch the threads, the prying action would probably damage them
If you know ahead of time that you need to loosen, PBlaster it to death the day before and again before loosening
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
Been thanked: 4065 times
That would take a really good touch to Dremel without damaging the thread. The Dremel bit is circular so you have to control the depth of a few mm at the deepest circumference of the cut.
You might be able to measure the depth and mark the Dremel bit with a sharpie, but those bits usually wear as you cut and change the radius .....sounds tough.
Maybe practice on an old one from a junkyard?
vjaneczko
Year and Model: 2006 S60R
Post by vjaneczko »
You can't loosen that c-clip, it's held in place by the pressure of the nut bolted into the hose, so you'd have to break it & replace it. Another challenge would be your idea of sliding the connection up (indicated by the red box & arrow in your pic). The hard line may not bend enough with the proper alignment, and (2) the nut may not lineup with the hole in the mounting bracket so it wouldn't slide very much. Another thought would be that whatever caused the two parts to become seized will probably not 'let go' easily, and with all the dremmeling you'd have to do, odds are pretty good you'd chew-up the threads of the nut, which you're trying to save.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
rmmagow
Year and Model: V70 1998
Post by rmmagow »
I've been using this as replacement line:
https://www.amazon.com/SUR-Auto-Parts-SR ... SJEBJ0MJ9V
It is easy to bend and flare. I had all the brake lines replaced in my truck with this stuff and the lines are still clean and healthy looking after three years of salted New England roads.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Baptiste1106
Year and Model: 850 1994
Post by Baptiste1106 »
Hey need some help. Just bought the double flaring kit and need help with the flaring process. I cut the line with the hacksaw already. I slipped the new nut on the line. Which hole does the line go thru, 3/16? Which flaring adapter do i use, 3/16? Then what ?
vjaneczko
Post by vjaneczko »
Yes, go with the 3/16 setup. The line will go into the hole, which will feel slightly tight when in the tool. The tool should have some grooves in it to hold the line firmly so it won't slide out. There's a few videos on YouTube that you can watch, too.
I can't stress enough the need to practice on a spare hose before you get onto the car. It'll give you the confidence you need to repair the car AND drive it!
2006 S60R - For ME!
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 11 times
Post by deepsouth »
Great beginning quote. I did this a year ago (rented the flaring tool from Autozone) and am still traumatized by the experience. The flaring tool is a SERIOUS PITA. Perhaps with practice it becomes easier but I found it brutal...
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
