'99 V70 Seat Refurb - In praise of the seatbelt release tab
This topic is in the MVS Volvo Repair Database » Volvo Seatbelt Release Tab: It Exists
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Although I have swapped seats between vehicles, it was not until very recently that I learned of the "seatbelt release tab". I do not believe it has been mentioned previously in any of the seat-related posts I have read on this forum. I discovered it courtesy of Bob Elwood's seat recovering directions. It is present on the V70, but alas, I do not believe on the 850. Instead of removing the seatbelt anchoring torx bolt, one simply has to depress a small nub with a screwdriver to slide the seatbelt strap out of its connection point on the seat. This miraculous device saves lots of time and frustration since there is precious little room to swing a wrench to get the seatbelt off otherwise.
If you are removing seats in a V70, this little latch can save you quite a bit of time and frustration.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1609 times
Been thanked: 4065 times
Not to mention not having to go out and buy a Torx-NNN bit, NNN large.
I wish I had known about this last year.... :D
Voila!
Voila!
Lift front of switch plate, then remove. Push in tab w/thumbnail
E Showell
Post by E Showell »
In this case, a picture is worth 1,000 words. Thanks for the pic.
'95 855 auto (sold)
osman
Year and Model: 2002 c70 hardtop
Post by osman »
I learned it from my friend Omar at DIY garage austin, he showed it to me a few years back when I was replacing a seatbelt tensioner. I thought about all the seat swaps I had done previous not knowing about the quick release tab.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
E Showell
Post by E Showell »
So I got the front passenger seat in the '99 V70 recovered over the weekend. The seat back was a reclaimed skin from a power seat that I could never get to work in the car that I removed and installed on the existing manual seat. The seat bottom was supplied by Elwood Industries. The driver's seat -- new back and bottom -- awaits, probably this coming weekend. I hope to post some pics when done.
I posted, I want to say about two years ago, about seat skins I obtained from Elwood Industries that I had installed on the driver's seat of my '98 V70. This time I opted to self install. There are a few tricks one needs to keep in mind, but Bob's directions are reasonable and the quality of his product is outstanding -- I'd say superior to OEM, except that I don't have a real handle on long term durability at this point. Plus, he made himself available by cell phone over the weekend in case I had any questions about the install. I emailed him at least twice and spoke to him once on the phone during the install.
As has been noted before, his product is not cheap (in any sense of the word). He uses quality materials and fabricates each set of seat covers to order. He does a very nice job with them. If you live in a part of the country where you don't have your pick of used seats with good leather covers on them in junkyards for $50 a pop (that would describe my situation), then Bob's covers are a viable option, although I must confess, it is undoubtedly less expensive to employ the myriad of leather restoration products which others here have used to good effect and have posted about their results -- do a search of the forum before you dive in to this. My approach is clearly not the only viable option and is certainly among the priciest, but I cannot quarrel with the results thus far and self installing is not beyond your capabilities if you can do an ignition tune-up or brake job. Even if you can't do those, self installing seat covers can be done with a modicum of patience and perseverance. I'd say it is a two wrench job out of five.
'95 855 auto (sold)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Whoa. A true secret.
This post scheduled for inclusion in the VRD. Thanks guys!
Also -> Amazon link
Duly named the Showell tab ...it isn't having information.....it's about sharing it.....
E Showell
Post by E Showell »
I can't take that credit. Kudos to Bob Elwood of Elwood Industries, the replacement seat cover supplier. That little gem is tucked away in Bob's installation instructions.
'95 855 auto (sold)
Its the Showellwood Tab, then..... :D :D :D
