Drivers door power window switch repair Topic is solved
This topic is in the MVS Volvo Repair Database » V70 Drivers Door Power Window Switch Repair
kevn
Year and Model: 2x 1996 850R's
Post by kevn »
Very good, thank you. :D
Can I add... that some silicone spray on the window glass felt stuff tracks is a big help to keep the whole window machinery alive and un-stressed.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
EBay's got some switches in the 35.00 range for new part. Not total junk, I bought one for my to-be-sold s70 and it works well. I had a little trouble getting it to fit but really for the price not too bad. Will it last? don't know, won't know but it sure was cheap. Amazon has switch doctor for $55.00 and I have that in my V70 for the past 3 years.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Bob 88
Year and Model: V70 2.5 SE 10v '97
Post by Bob 88 »
Sometimes the lacquer on the heater knobs and door switches breaks down with age and becomes "tacky".
The best way I found to clean the stuff is "Wynns brake and clutch cleaner".
I was told that the problem was caused by new environmentally friendly compounds used in the lacquer which do not age well.
JBRollo
Year and Model: 2012 Volvo S60 T5
Post by JBRollo »
A can of Radio Shack contact cleaner and a can of compressed air (used for electronics) from Wal Mart really improved the process. Thanks for the instructions. It makes all the difference.
rude
Year and Model: v70 1999
Post by rude »
This quick fix was one of the best write-ups I've seen in this forum and has helped me greatly. However, during my most recent switch repair, after all the cleaning, the drivers window still would not go up everytime. I realized that under one of the contacts the contact and the striking metal were worn. So I purchased a new one from switch DR. however, my window was still in the down position. So instead of taking the door apart and wiring up a battery to the window motor, I took a pencil with an eraser and without putting the cover of the switch back on I plugged in the window switch and pushed the contacts together with the eraser and the window went up.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
FYI - There's no need to pull the door panel to power up the window.
The motor leads come straight to the switch. If you have the switch
out of the armrest, you have the wires you need right there.
Peixinho
Year and Model: V70 T5 -- 960 2.5
Post by Peixinho »
Just to say thanks to the contributors for this DIY. A couple of months ago i found out that the rear right window didn't come up on driver's switch, but that was not the problem. today the driver's window didn't come up and I just fixed it. thanks!
'96 960 2.5 manual
'98 V70 T5 Manual LPG
'02 S60 2.0 Manual LPG
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I had the dreaded no rr window inop situation on vacation many miles from home. I was able to finally get it to work by wiggling the switch.
Took apart Assym and cleaned contacts but 2 of the rods under the buttons came out. They are spring loaded but I'm not sure how they lock in. Has anyone had this problem. I'm using a screw driver without the cover to operate the windows
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Been thanked: 504 times
Post by cn90 »
See post from March 23, 2013.
mecheng
Post by mecheng »
Unfortunately it's not that pin. I'm not sure how the pins came out of their housing but I can't get them back in. There is no obvious way they lock. Anybody else have this issue? Or does anybody have an extra top switch section hanging around. The switches work perfect otherwise
FU
FU
Fu2
Fu2
