I own a 94 850 turbo where the AC will not cool above 2000 RPM's. While idling the AC is cold and will cycle once in a while the gauge shows levels are good. It works fine as long as I keep the RPMs below 2000 which is real hard. Once I over the 2000 RPMs the compressor will not kick in until the car is restarted.
I thought it must be the high pressure switch and have swapped it out. A mechanic told be to change the cycle switch but I don't know where to look.
My neighbor has an 02 V70 that is doing the same thing, only difference is theirs doesn't show a pattern and some days the AC works all day.
Any suggestions.
Brian
1994 850 Turbo AC inoperative MVSOLVED Clutch gap problem
- Been thanked: 4071 times
That sounds like classic compressor gap problem. It can be fixed by reshimming (for purists) or by the googable "Volvo AC bread clip fix"
I should point out that, if I race it off the line then let off the AC will stay on, it only happens if I drive continually faster than 2000 RPMs. Also, I can turn the AC off and after a few moments it will kick back on but that only happens once in a while.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Cooling Fan or Compressor?csbrianp wrote:I should point out that, if I race it off the line then let off the AC will stay on, it only happens if I drive continually faster than 2000 RPMs. Also, I can turn the AC off and after a few moments it will kick back on but that only happens once in a while.
Never mind ghetto clutch gap worked. Thanks guys.xHeart wrote:Cooling Fan or Compressor?csbrianp wrote:I should point out that, if I race it off the line then let off the AC will stay on, it only happens if I drive continually faster than 2000 RPMs. Also, I can turn the AC off and after a few moments it will kick back on but that only happens once in a while.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 11 Replies
- 6966 Views
Last post by ThreeBear
- 10 Replies
- 2464 Views
- 2745 Views
Last post by victoriaemmy
- 10 Replies
- 2195 Views
- 1098 Views
Last post by E Showell
