I am needing to replace 3 sections of the steel fuel pipe on my 1999 V40.
Does anyone happen to know the measurements that I need to identify the right pipe to use?
I need to replace about a metre of the end near the fuel pump of all 3 of the steel pipes that go between the nylon(?) pipes marked D on the attached diagram and the main straight parts/rails that run along the length of the car.
I am looking at using copper pipe at the moment with the measurements below and hoping I am going to be able to do the job with a basic flaring tool:
OUTSIDE DIAMETER 8MM
@ WALL THICKNESS 0.71MM
@ SAFE WORKING PRESSURE 1044 PSI 72 BAR
http://www.volvopartswebstore.com/showA ... bly=236783
