95 Volvo 850 T5R how-to bypass a/c thermal switch
This topic is in the MVS Volvo Repair Database » Volvo 850 How-To Bypass AC Thermal Switch
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Since its that time of season and I had problems with my A/C thermal causing me problems I thought I would do a "how-to" on bypassing it. I couldn't find anything with pictures so here you go :)
First pic is of the A/C thermal ( after I've cut the wires on both ends ) but it gives you a clear shot of what it looks like
second pic shows the connector you need to disconnect that comes from the harness to the thermal
This is the wire coming out of the back of the thermal ( back side of compressor ) cut it as close to the thermal as you can
This is the wire stripped coming out of the front of the thermal getting ready to connect to the wire that went to the back of the thermal
Wires tied together ( should use a butt connector or solder ) I did this for a quick pic...
Finished result.. just plug the connectors back together and your done.. basically you should have what looks like in the first pic ( a square thermal with wires cut on each end )
1996 Platinum Edition
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
Thank you. Nice write up.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
phils94850
my pleasure :)
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Isn't that a protective device?
Why not just replace it?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The high temp switch was problematic and was deleted later. The compressor mfr left it on as it was not needed by Volvos with hig pressure switch since that also is the protection fro compressor overheat.
I deleted them by unplugging the power lead from engine harness to wire into switch and unplugging the wire out of switch to the wire to clutch magnetic coil. Then you plug the power wire directly to clutch coil wire leaving the switch wires hanging in the breeze.
phils94850
what jimmy said :)
BEJinFbk
Post by BEJinFbk »
Cool - Thanks for the back story.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Very nice, Phil. I'll put this in the Volvo Repair Database.
Also -> Amazon link
phils94850
thanks matt.. just trying to give back :)
