+1 on this advice. I pulled the turbo off my 94 850 before scrapping it and it was not an easy job. All the fittings will likely be rusted/stuck and some are in very awkward positions. Do the easy part first and see what happens you might just save yourself a lot of work and headache.jblackburn wrote:Fix the coolant lines first and see if it still spins/boosts.
If not, pick up a used turbo at a junkyard. Check it for play - if there's little-no horizontal play, stick it in the car and don't worry about it.
98 V70 AWD Coolant System Failure - Turbo Fried
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Re: 98 V70 AWD Coolant System Failure - Turbo Fried
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
shegarty
of course it does ... it's a Dodgetryingbe wrote:You should try pulling a turbo on a 80's turbo dodge, head has to come off!
quadzillabill
- Year and Model: 1998 V70 T5 AWD
Well, things got worse. I was hesitant to let the original place do the work and after talking to another mechanic he convinced me to bring it to his place to make sure the head gasket wasn't blown. We got it over there and he was able to fit some temporary cooling lines to do a short test run with water. Low and behold, the head gasket is shot as well. Good thing I didn't throw $1200 at the turbo.
This same guy will do a used engine install for me for roughly $750 and it seems that finding something decent with a bit lower mileage might be a reasonable way to go. What are some good sources for a salvaged engine?
- Has thanked: 1503 times
- Been thanked: 3817 times
Southern Volvo and Erie Volvo .....just look up at the banner ads
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I inspected my turbo coolant hose, it is bulging. I bought all the hoses and washers, will install soon.
I'd recommend everyone to have a look this.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Has thanked: 292 times
- Been thanked: 765 times
Actually there are two of them, check (and likely replace) them both.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
mecheng
Yes, I bought both but only the hose adjacent to the turbo is bulging a bit on both the 850 and S70. I noticed that the screw clamp can't be accessed from under the car, I will try from top or try turning it.erikv11 wrote:Actually there are two of them, check (and likely replace) them both.
- Been thanked: 471 times
@mecheng,
Actually you can access the clamp from below. The key thing is to get a very long screwdriver (I have the 16-inch long screwdriver, $8 at hardware store, or Sears) and push on the clamp to turn it so the screw faces you.
All the tips/tricks are below. BTW, use Volvo OEM hoses only!
DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hoses
https://www.matthewsvolvosite.com/forums ... hp?t=55306
