Heater motor?
ericg30062
- Year and Model: 99 Volvo S70
Heater motor?
My Volvo S70 heater keeps going on and off. Would this be a bad motor. I also must add that i just got the update from Volvo. Help. Thanks in advance.
bobsnow100
- Year and Model:
It sounds like the heater relay or the resistor.
VOLVO850740
- Year and Model:
Mine went in my 850 it was the resistor. I bought one on ebay used and mechanic put it in. Works great now on all speeds. It use to only work on high speed.
- Year and Model: Many Volvos
- Been thanked: 75 times
Do you have the automatic climate control or the manual climate control?
If you have the manual climate control and the blower works on only fan speed 4 you indeed have a bad blower resistor. If it is the auto climate control you need to dump the codes out of socket B-1 and post them for us. That should tell us for sure what your problem is.
ericg30062
I have a manual control Lee I have notice that when I start up my car, the heater is working fine, then after it heats up, once I give the car some gas, it stop blowing and then a few min later it will not blow any air. Now here the funny part. it will come back on a few min later but not at full blast. Hope this helps.
- 32 Replies
- 16021 Views
Last post by sleddriver
- 23 Replies
- 5714 Views
Last post by callahanoffroad
