1996 850 turbo rough idle and stutter
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Have you changed the ECT? Checked the wires on it?
- Has thanked: 1611 times
- Been thanked: 4074 times
Have you fixed that vacuum leak? That could be the whole problem. You probably have more than one leak and they will mess up your running.
steve850
- Year and Model: XC70, 2004 and 2010
- Been thanked: 3 times
Fixed the vacuum leak, no change. Strange thing is i was messing around with different hoses checking things and accidentally left that hose disconnected, and the car behaves exactly the same. Hoping to pick up a coil tomorrow and try that. Running out of things to replace !
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
That's pointing you to another vacuum leak....somewhere.
Smoke test PCV
Fuel pressure regulator torn?
Smoke test PCV
steve850
Put a new (used) coil on today, no change. Checked the ETC and found one lead disconnected, not sure that happened the other day when i was messing around with the vacuum hose on the end of the intake manifold...Anyway, starts and runs better when cold, or after sitting, idles better but only runs for about 10 seconds then dies. After five minutes of starting and stalling it won't start unless i pump the gas...if i push the revs up it cuts in and out. I'm starting to think fuel issues. The filter is new, the pump is about 3 years old. Could be the screen have picked up some crud or the pump won't hold pressure...? Am i correct in thinking that the proper fuel pressure at the rail is around 42 pounds? My guage only goes to 10 so i'll have to get another one to test...
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
steve850
Found that whoever last changed the pump didn't replace the whole unit, just the pump. The in-tank hose was clamped below the metal hose, and not properly secured, so i expect half the fuel was not getting to the engine. Unfortunately, the metal lines on the outside of the pump were rusted and one of the broke while i was popping the lines off, so in goes a new one. We'll see what that does ... !
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
steve850
Smoke tested again today to double check, no leaks. Just got the fuel pump, hope to put it in tomorrow. If this doesn't do it...??
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
- 3873 Views
Last post by marmotteNZ
- 1746 Views
Last post by fartoright
- 1270 Views
Last post by jonesboy1983
- 983 Views
Last post by bigkitty
- 2055 Views
Last post by rob81712
