2001 v70 TCM 0020 and TCM 001F codes from VIDA
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
So, minding my own business, I start up the car one recent morning, and get both a "Check Engine" Light and a Warning Triangle in the center of the dash, with an explanation from the DIM "Transmission Service Required".
Hooked up the VIDA, and it tells me that the "Check Engine" is the usual false positive that seems to be cured by removing and replacing my (locking) gas cap on after a fill-up.
But the tranny codes are TCM 0020 and TCM 001F.
Both are speed sensor problems.
Hard to imagine that these would crop up at start-up after sitting overnight, but I suspect a pothole causing a connector to give up the ghost.
Drove from NYC to Groton CT and back with this problem , and I noticed no problem with shifting.
I figured I'd see the "too many hours of hot tranny fluid" error due to a lack of proper code clearing when tranny fluid was changed, and the 189K miles on the beastie. But nope, I got sensor codes.
Does anyone have any wisdom on any commonality between these two speed sensors? Might they share the same grounding wire? I can certainly ohm out the CANBUS wire and check for power on the power wire, but I do not have any prior experience with either of these sensors.
There appear to be no tales of woe and intrigue that mention these codes.
May I please buy a vowel?
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
packetfire
Update to above - the errors can be cleared with VIDA, but reappear within a few miles of bouncing around on city street potholes, so I am guessing that this is a bad connection somewhere. Interesting that the Check Engine light comes on WITH the transmission warning each time.
