One one side you have factory Volvo, Hutchinson Corteco and Lemfoerder. On the other side, you have Pro Parts, Meyle, Febi, URO, Rein and even more mystery brands if you look at Rock Auto. Good mounts run about $300+ for the front, rear and side, with the cheap ones running about half to 1/4 that. My question is, are the cheap mounts worthy? Do they last? do they fit properly?
My '96 850 Turbo needs at least three new mounts, front, rear and side (near the crank pulley) It may or may not need the lower torque arm. I will likely have the car another 2+ years, maybe longer. Heck, I've been driving it for 12 years already!
Motor Mounts, cheap vs. expensive
- Year and Model: Many Volvos
- Been thanked: 76 times
I put a URO front mount on my sons car about 10k miles ago and it is now worse than the bad OEM mount that it replaced.
Seaway
- Year and Model: 1998 V70 T5 Manual
After doing a ton of work on a couple old Mercedes, I would never put Uro anything on my car. The stories of immediate part failures are far too common. I would imagine this holds true for Uro parts for Volvo as well.
Motor mounts can make a huge difference in the feel of the car. If you want to drive the car for a while I would use OEM or better.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
I've replaced the mount near the crank pulley twice in 12 years. Once with a Scan-Tech, and once with a Febi. Maybe I just answered my own question ???
- Has thanked: 311 times
- Been thanked: 817 times
For the front (near the crank pulley) mount: Lemforder
Russ..did you check the "parts forum" for feedback on the motor mounts and OEM vs off brand perennial issue?
- RussB
abscate wrote:Russ..did you check the "parts forum" for feedback on the motor mounts and OEM vs off brand perennial issue?
I did not, but will now
IMHO
Please avoid Scan Tech asian krap and the other similar pos junk.
If IPD has a mount you need, get the IPD. If IPD doesn't offer the mount, get oem. IPD well sell you those as well if you wish.
Usually, if I put an IPD mount in, it never had to be replaced until I sold the 854t5 I drove for 16 years. I did have to replace the top mount once, I think IPD sent me a new donut no charge. I have a fat foot, which stresses the motor mounts a lot.
You won't find an increase in motor vibration if you replace all the mounts at the same time. Stories of additional virbration from the IPD mounts invariably turn out to be another mount(s) also due for replacement.
No, I don't work for IPD, I do like to support folks who provide very good products with excellent service, if only due to its rarity today.
Good luck
Good luck
- RussB
IPD sells low end "junk" mounts as well as OEM units, and a "billet" lower torque rod for a 170 clams...LOL
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
in the case of, for example, the transmission torque mount, "nice" parts are much more expensive than the regular or "cheap" parts (see the IPD torque mount referenced above - very nice, but also pretty excessive), and the time to replace is just about zero.
in cases like that - failure is not catastrophic to the car, replacement time is minimal, cost of cheap part is low - i'm a proponent of cheap parts. if it fails, nbd. you can buy a better part and replace it and you're no worse off. if it doesn't fail, you saved yourself some money.
- 9 Replies
- 2133 Views
Last post by 800artfreed
- 829 Views
Last post by Goupil
- 1437 Views
- 13 Replies
- 4310 Views
Last post by matthew1
- 52 Replies
- 13562 Views
