Big trouble with my 2008 XC70- 128,000 mi total. Drove 1500 highway mi in the last two days after replacing two front tires, Replacing all four struts, and getting 4w alignment.
In the last 200 mi strange vibration started in front on acceleration then grew worse and traveled to feel like it is coming from under the middle console between front seats.Feels like a bucking bronco when the pedal's down, then disappears when I lift.
Obviously, I am thinking Halex and know the cautions about different sized tires.
I thought the new generation of AWD could handle a tiny change between slightly worn rears and new fronts. Tires are all Pirelli p-Zeros. Temps have been hot here in the NE (80-90F)
Any ideas what could cause this, or even better, fix it?
08 XC70 Bucking Bronco
replicapro
- Year and Model: 2008 XC70
More info on this: I had a chance to look under the car this morning and nothing is obviously bad there.
Both front axles seem solid with no play. The prop shaft has about 2mm play but nothing leaking or worn at either end. No burning smells at any time. I did get a check engine light after replacing the tires, 1500mi. ago, but it went away after three start cycles. Vibration is like a really rough corduroy road under load, then smooth as silk when I lift. My guess now is perhaps engine mounts? Anyone?
midniteliquid
- Year and Model: 2011 XC70 T6
Are the tires the same on the front as they are on the back with the exception being the fronts are newer?
Volvo #1: 1996 850 GLT (now my Sister's...)
Volvo #2: 1995 850 T5R (totalled... rear-ended by a woman on her phone)
Volvo #3: MY2011 XC70 T6 (current... I love, love, love this car!!)
replicapro
Update on the Volvo Bronco: Rear main driveshaft removed. Problem gone. Now to decide if I want to spend a ridiculous $1200 for a discounted new shaft from Volvo before the snow flies. Erie VoVo also has used for $675. probably where I am headed.
Thanks for the help
Thanks for the help
JDS60R
- Been thanked: 3 times
Its usually just dry grease on the end cv joints of the center shaft(usually the front one) . You can repack them with quality synthetic grease and inspect for damage, or just buy new ends.
If your boots are ripped here is an affordable source.
http://www.driveshaftparts.com/cv-joints-shafts/volvo/
Retired
- Year and Model: Lots
- Been thanked: 128 times
That's a great resource JDSR60!!
Who thought you could buy CV parts separately like that!!
- 810 Views
Last post by jblackburn
- 2368 Views
Last post by carboncow
- 3347 Views
Last post by oragex
- 3239 Views
Last post by P2Apprentice
- 3616 Views
Last post by erikv11
