1999 V70R light problems, MVSolved, hatch wiring failure
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
when I connect my trouble light to the plug leading back into the car it will not light and the fuse will not blow. If connect the plugs the fuse will blow it about 40 seconds. With the license plate plugs disconnected the LF cornor light operates. I don't understand why the trouble light does not light but when the plugs are connected the fuse will blow.
- image.jpg (217.5 KiB) Viewed 1128 times
kahl
thank you Mike and Abscante for your help. Here is a recap: front left cornor light and license plate light share fuse 23. Fuse 23 keeps blowing unless the license plate light is disconnected. rear wiper was inop. There is a problem with wire bundle going to hatch. thanks to Mike pointing this out I searched hatch wire bundle in the repair data base. That thread led me directly to the left wire bundle and how to remove and repair. I cut off the plastic sheathing and pulled down the snake skin to reveal the broken wires. To reinstall I used 3/8 open loom secured with electrical tape. Then I pulled over the snake skin.
- image.jpg (227.06 KiB) Viewed 1122 times
- image.jpg (257.16 KiB) Viewed 1122 times
- image.jpg (168.45 KiB) Viewed 1122 times
- Been thanked: 4069 times
Nice work kahl. I only had one wire broken in that cluster on my 1999. It has cropped up in several threads recently!
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Mine has blown fuse 23 three times in the past month so tailgate wiring job is on the cards for next weekend, if you do check the wires test them by pulling them as sometimes the copper conductor breaks but leaves the insulation intact which makes the wire look ok externally but given time the copper will break out od short.
When the tailgate loom is as bad as the above pictures it is obvious once you expose the wires that things are not as they should be, it is when they get as bad as this combined with a higher than intended fuse rating inserted that electrical fires can start which cause serious damage to the wiring loom, looks like you caught this one just in time - Mike
Bumped thread to link to recent question on wiper outagekahl wrote:I think I found my problem in the left hinge wiring bundle. What a stinking mess.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Thanks, Steve. No joy as of yet with the PB Blaster, so it looks like I may be headed into the loom after all to fix my inoperable rear wiper. Now I know what to look forward to.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Before you cut into it, if you have the motor exposed, turn on ignition and wiper switch and probe all the wires for 12 volts. Volt scale on meter, one probe to ground, the other onto each terminal. If you can't find 12v, it's wire loom time. Repairing that loom isn't too bad. Sharp knife to open up the insulation, matching black tape to wrap it up afterwards
- 1233 Views
Last post by zanzabar
- 10 Replies
- 5500 Views
- 11 Replies
- 932 Views
Last post by Eyesiic
- 1675 Views
Last post by polskamafia mjl
- 11 Replies
- 3458 Views
