2001 V70 2.4T What would it take do do a T5 Upgrade?
volvoknorr8
- Year and Model: V70 2.4T 2001
I know that the T5 uses a high pressure turbo vs the low pressure turbo in my 2.4T, would swapping out the turbo be sufficient to upgrade the car or would there be ecu changes needed as well? And would I need to invest in an intercooler?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
I believe this has been tossed aroud a few times, but... It will take an ecu remap, probably injectors, intercooler. Not sure about compression reduction..
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
volvoknorr8
So in other words, if I want more performance I should just chip the ecu....
- Year and Model: Lots
- Been thanked: 128 times
You're currently running 9:1 compression. HPTs run 8.5:1
Introducing extra boost should be done with great care as you can easily overboost an LPT engine with a T5 setup of turbo and ECU. Crank rods are usually the first casualties.
Personally I would stick with a LPT tune and a modified exhaust. Take a look at some of the packages that IPD Volvo provide. 30-35 hp is easily obtained and the car will be very driveable.
volvoknorr8
Thanks alot for your input!precopster wrote:You're currently running 9:1 compression. HPTs run 8.5:1
- Has thanked: 1502 times
- Been thanked: 3817 times
Without trashing MVS, is there more on this topic over on SwedeSpeed or the others?
- 2931 Views
Last post by phils94850
- 10 Replies
- 960 Views
Last post by saq
