88 240 not charging, checked all i can think of
Silver Brick
- Year and Model: DL Wagon, 1984
I had very similar problems with my '84. Only after running a temporary ground wire from the alternator case to one of the upper strut mounting bolts did my battery start charging as it should. I don't know if my former mechanic's hammer wielding helper left off the ground strap or what, but that temporary wire was replaced by a permanent grounding strap.
BTW, here is where I got that info: https://www.matthewsvolvosite.com/forums ... =2&t=26627
Beware though, there starts to be some conflicting info about halfway dealing with whether or not the battery or alt bulb is functioning. -Seems more people are of the opinion +12V starts running through both sides of the terminal for that bulb cancelling itself out.
Hey man I made you a picture.
Whatever is going on, this is the proper wiring for OEM:
Giant pic:
Only thing I can think of why it's not charging is either *exciter or *ground.
If it's exciter then you should check that grey box at the firewall to make sure the wiring isn't all eaten away. If so then you'll need to wrap each wire individually with gorilla tape or something equally strong enough to stop the problem unlit you can get a new harness or replacement wires.
I found out what was wrong with mine. -The previous owner's high dollar mechanic.
I should have put orientation in the image, but it's very easy to get mixed up with that lower bolt for the bushes and the post for the ground. It might actually work if you connected the ground to one of those brush/regulator bolts, but I don't know. For you, since you haven't mentioned anything about that grey box connector, you really need to check that. it starts looking like a rat's nest of copper and causes all sorts of ignorant problems.
Giant pic:
Silver Brick
Go to kjet.org. Look under Green books. Find the one for Battery, Alternator, & Starter. It may or may not be listed for an '88, but maybe it'll help you.
lummert wrote:The 12V exciter wire usually has an indicator bulb between the source and the alternator. The purpose of this bulb is not just an indicator.
That bulb seems to be pretty important as it's being used in a interesting way. They say when everything is working right, both sides to it give positive current, cancelling each other out.
- 16594 Views
Last post by Richard99
- 12 Replies
- 2790 Views
Last post by brushhippie
- 30 Replies
- 4922 Views
Last post by polskamafia mjl
- 2297 Views
Last post by popphl
- 1103 Views
Last post by cn90
