1997 855 Sway links
Jush
Year and Model: 1997 855 GLT
Post by Jush »
I was just wondering if anyone knew of a replacement part that had a hex part on the stud so you can tighten the links to maximum potential, I can't get a wrench to stay tight on the small style ones that only allow for a single wrench position.
for example, what I would want is something like this: Image
But all I can find are ones like this: Image
I have replaced the links 2 times now and since I can not tighten them to their full potential they still rattle around due to not being tight enough..
Unless anyone has any tricks..
Thanks
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
By design, these also come with counter-hold for a 16mm wrench to fit, right next to the boot.
cn90 says to use bicycle wrench - it has worked for me.
Lemförders come with torx on stud for counter-hold.
dosbricks
Been thanked: 4 times
Post by dosbricks »
Take a look at Meyle HD from FCP:
http://www.fcpeuro.com/products/volvo-s ... -v70-850-1
Heavy duty--bigger shaft, heads, studs, and importantly--bigger flange nut with more bearing area on the strut bracket.
Jush
Post by Jush »
I have bicycle wrenches I used to work on bikes for a long time I remember trying to use one but I can't remember if it fit in the space provided on the strut mount.
I would like a bigger hex to hold because then I can use my impact gun to keep them tight as heck.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
dosbricks wrote:Take a look at Meyle HD from FCP:
I like the Meyles and instead of using the 16mm open ended design they use a T40 which you can purchase with a 3/8 inbuilt drive.
xHeart
Post by xHeart »
Jush wrote:I have bicycle wrenches I used to work on bikes for a long time I remember trying to use one but I can't remember if it fit in the space provided on the strut mount.
No need to tighten than recommended.
It uses lock-nut, and torque on these nuts are normal.
For $20 each, it can be replaced with relative ease every few years.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Jush
Post by Jush »
Thanks for the video Rob, although I am familiar with the replacement procedure.
I guess I'll just have to try again.
Fun fact - Those thin bicycle wenches are called "cone nut wrench(s)" Typically used to adjust hub tightness on loose-pack bearing wheel hubs!
