My factory dipstick lasted 14y/140K. So not bad at all.
Chances are I don't keep the car that long (280K) to need another dipstick.
1998 S70 Broken dipstick
- DragosGD
- Year and Model: S70 T5 - 1998
- Has thanked: 9 times
- Been thanked: 6 times
Well, the original one maybe... but the new ones are trash! 30K Tops! Why do you think I have to replace my 1271920 ?? Beside that... the round wire style holds strong in the tube when you pull it out, which made the flat blade style the winer!!! Like Dutchtouch1 sad before, "Good luck"!
- Been thanked: 504 times
The dipstick is made by many many people, Volvo, the aftermarket etc.
The Volvo OEM disptick lasts > 10 years.
You may have bought an aftermarket dipstick.
- DragosGD
Bad news: genuine 1271920 dipstick from TASCA with VOLVO label on it - gone in less than 30K miles.
I'm not going over this again. Good luck with your choice!!
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
You never used it as a prybar, no?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- Year and Model: Lots
- Been thanked: 128 times
If you think the new OEM is bad you should see the Scantech dipsticks. They probably won't last 5K miles.
I think the solution should be a "better" O-ring.
The Volvo O-ring tends to be a tiny bit tight. In the process of pulling the dipstick out with a tight O-ring the round plastic handle may crack.
Given that many of these cars are over 150K-200K miles, I wonder if we need the black O-ring at all.
If the O-ring is removed (store it for later):
- You won't have cracked dipstick because it is easy to pull out.
- Your PCV system will breathe better!
It won't be much of a PVC "system" if it leaks fumes into the air we breathe!!
The Scantech one I bought has almost no grip from the o ring seals so likely that one is leaking all the time.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
My daughter upgraded to the new dipstick and has a hard time pulling it out to check the level. Very tight.
- 2586 Views
Last post by E Showell
- 1384 Views
Last post by songzunhuang
- 789 Views
Last post by Ludermilch
- 60 Replies
- 8065 Views
Last post by ericmci
- 30 Replies
- 9217 Views
Last post by Ben850
