1992 240 ignition coil wiring
rmozer
Year and Model:
Post by rmozer »
Can anyone help me to know which terminal wires go to which terminal on my new ignition coil?
There's a red/white wire and a blue wire.
The terminals are labeled -1 and +15. Based on their position using my old coil as a guide, it looks like the red/white goes to the -1 and the blue goes to the +15.
Is that correct?
If I connect them backwards, will it cause damage to the new coil? or to anything else?
Thanks.
Bob :?:
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Key switch on...use voltmeter...postive to positive
morsing
Year and Model: 1989 240
Post by morsing »
Huh?
How does that help him? I'm looking at the same problem.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Blue wire goes to 15, Red/White goes to 1.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
morsing wrote: 11 Nov 2023, 07:02 Huh?
Back when dinosaurs and carbs still roamed the earth,
every motorhead had a handle on basic coil theory.
12v + is supplied to the coil at all times when the key is in run.
The - side of the coil is the side that's connected and disconnected
to ground at the right time by the ignition system to generate spark.
So, only one of those two wires will show 12+ with the key on.
All part of the charm of owning a pre-coilpack Volvo. πŸ‘
