1995 850T How many miles does your 850 have?
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
99 T5, it'll hit 245k either today or tomorrow. from what i can tell, this is on original everything except wear and maintenance items.
i do need to replace those valve stem seals, but oil is cheap....
dosbricks
Been thanked: 4 times
Post by dosbricks »
mecheng wrote: I suggest we change the title to show some love for the better looking S70s. :D How many miles does your 850/S70 have?
Hey, I got one! She's a beaut', and a contender at 223k. :D
-ovlov-
Year and Model: 850 1995
Post by -ovlov- »
Hi!
According to miles/kilometers conversion calculator, my 95 brick shows 230000 miles (around 370000 km).
That is before instrument cluster repair last month(odometer gear repair).I own that car for about 6 month now.(got it with the cluster already broken) I drive around 600 miles monthly.That is 3600 miles to add.I have no idea of previous owners driving habits besides the lack of proper maintenance and negligence towards this fine piece of engineering or for how long it (cluster)had been broken.
ImageVOLVO 850 Estate 1994 - R.I.P.
ImageVOLVO 850 Estate 1995
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
We have an 95 850 with 89K miles, a non turbo 2000 V70 with 190k miles and a newly aquired V70R on the other end of the pole with around 247K miles.
The V70R is getting a new HG this week but only because the previous owner neglected the timing pulleys and bent valves. Must check the engine number to see if it's original.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
precopster wrote:We have an 95 850 with 89K miles, a non turbo 2000 V70 with 190k miles and a newly aquired V70R on the other end of the pole with around 247K miles.
Which pulley seized? Was it original?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
-ovlov- wrote:Hi!
You can get the actual mileage from that car.
The idler pulley was coarse and the tensioner pulley was very noisy. Who knows perhaps the timing belt snapped. I'll never know because I purchased the car from a 3rd party and the head was already removed and timing belt discarded.
See topic: https://www.matthewsvolvosite.com/forums ... hp?t=65172
polskamafia mjl
Has thanked: 19 times
Post by polskamafia mjl »
You spelled 850 wrong.
2012
Year and Model: 1995 850
Post by 2012 »
A clean 850 will turn more heads than a clean S70.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
212 864miles on my 850 T5-R.
Looks like 2nd gearbox.
currently It is leaking quite a bit of ATF. Otherwise no engine or transmission issues. Hope It is just the dipstick or something, it started leaking somtime after I changed the pnp switch.
850 T5-R '95 auto Image
