Great write up, has me wanting to tackle my 'noids. Haha!
My 94 wagon is approaching the 200k Mark, and the lockup solenoid seems to not work. Rpm's stay close to 3k on the highway at 70. Where under the cover is the lockup noid, or does one of the others pull double duty?
Volvo 850 S2 Transmission Solenoid Replacement w/Pics
Volvo 850 S2 Transmission Shift Solenoid Replacement w/Pics
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
That's a good question. In the picture above that I posted showing S1 and S2 there's a third solenoid at the bottom. I'm guessing that must be the lock up. I don't see any other solenoids there and I know lock up is a separate unit.
daversm
- Year and Model: 850 1994
yup the lock up is at the bottom, I actually just ordered one:
http://transpartsdirect.com/aw50-4042le ... 11994.html
Its coming tomorrow, so if you can wait over the weekend I can't let you know if that solenoid works, after I install it.
polskamafia mjl
So Im at the point where I need to remove the ATF cooler line from transmission pan cover. There are two bolts, one on top of the other. Which one do I undo to remove the hose? I've tried both and neither is moving. PB Blaster and a torch don't seem to have helped much. Any advice?
polskamafia mjl
Wow.
I really shouldn't be allowed to work on cars. Can't believe I didn't think of that.
polskamafia mjl
Good news! I got the S2 and lock up solenoids replaced and everything put back together.
Bad news! My gasket paper did not work at all and I'm leaking ATF like a sieve. Looks like I'm going to have to drop the subframe and use RTV after all. Such is life. And for what its worth, my S1 solenoid is one of the later ones; it is different than the S2.
daversm
I just replaced my s2 and lock up also, All is working perfectly thus far.
Also got all parts from trans parts direct.
I also used gasket paper, Ive had no problems thus far.
This is the Gasket paper I used.
http://www.oreillyauto.com/site/c/detai ... &ppt=C1984
I really hope I don't get a leak in the future, that would suck so much.
- 2008 Views
Last post by smileyboy
- 5680 Views
Last post by SuperHerman
- 637 Views
Last post by crazycat
- 1609 Views
Last post by Geno9707
- 1338 Views
