DIY: 1997 Volvo 850 - a supplement to Rear End Delta Link...
This topic is in the MVS Volvo Repair Database » Supplement to Delta Link Replacement
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
skloon wrote:Wow is that what it looked like, I was too busy under the car swearing and beating on the bolts into the transverse bushings to notice, had to resort to the sawzall great photos
Agreed! Those old bushings are just insane to remove, and I'll bet that all 850's need to have them replaced
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Marking for rear wheel alignment
This step is needed for installation, and then safely driving to your favorite alignment shop for final and accurate all wheel alignment. I pay $74, see the report above.
All nuts, bolts and screws were PB Blasted overnight.
After I had the car on 4 jack-stands, rear wheels off.
Break just the outer nut loose. It is extremely tight, screams loud. It takes 13/16" socket on 1/2" breaker bar. Once loose it will unscrew with ease.
a picture after installation - red arrow at outer nut
Pull out the screw, and thoroughly brush the area clean. Your toothbrush experience will help here, Lol.
Take a closer look as to where the two holes (mount, and the mount-location on transverse arm) are aligned, and where you will place the markers.
In my case, the corresponding holes were not centered. I noticed an arc, which suggested the mount was pulled forward. I made two marks with 1/4" chisel at the inner end of the arc.
a marker at the mount-location - pictured before installation
a corresponding mark on mount itself - pictured after mount was removed
Highlight the marker with paint before transferring it on to a new replacement mount.
highlight and transfer marker to new mount
Now proceed with removing every nut that must be removed for this project.
blandis
Year and Model: 99 S70 T5
Been thanked: 3 times
Post by blandis »
Pic using the delta link tool to install the delta link bushing. Works like a charm. Used a bit of vaseline on the end of mine, got it started by hand and used the impact to slowly run it in. Will run it past where the holes line up for the bolt. Use a drift/punch to line it up again.
Rent the tool.... spend the few extra bucks to do so. Can not say that enough.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Has thanked: 311 times
Been thanked: 817 times
Which delta link bushings and anchorage mounts did you guys buy?
RussB
Post by RussB »
Delta links - ScanTech (purchased circa 2010)
Driver's side trailing arm bushing - ProParts Sweden (made in Taiwan)
Pass. side trailing arm bushing - ScanTech (purchased circa '06)
blandis
Post by blandis »
Febi 3516122 from eeuro
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
xHeart
Post by xHeart »
All four are Volvo from a local craigslister more than a year ago for $100 cash .
I use OE for little more to avoid fitting circus. Truly a great ride after replacement.
1997 MY is between 96 850 and 98 S70.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Is that Febi Bilsteins? Where are they made?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
xHeart
Post by xHeart »
mecheng wrote:Is that Febi Bilsteins? Where are they made?
Who knows, but it claims to be a German manufacturer http://www.febi.com/febius/car-division/presentation-car-division.html
blandis
Post by blandis »
What I received were red box Febi Bilstien. I have had great luck with Febi over the years.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
