I have 98 S70 GLT that has the classic symptom of the ABS and TRAC warning lights coming on and going off. Being a cheap skate, I went to a local junkyard and got a control unit from a '00 S70 GLT. When I removed my unit I noticed that there are significant internal differences between the two modules.
My unit Part# 9162675 "CONTROL UNIT TRAC 2/4 WD" has 7 coils
Junk Yard unit Part# 9472971 "CONTROL UNIT /STC" has 10 coils
The 7 coils on my unit align with 7 of the 10 on the Junk Yard unit.
Is it possible that I can get away with using the Junk Yard unit?
Thanks for any response.
1998 S70 GLT ABS Control Module Compatibility
- Has thanked: 292 times
- Been thanked: 765 times
96-98 are all the same, then 99-00 are different; in all these years of people dealing with their failed ABS modules I have never heard of someone pulling off that swap. I would say 99.95% chance it will not work.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
It won't work. At all.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
It doesn't have to be from a 98, any 96-98 Tracs module will do. If you don't care about having Tracs, which wouldn't be missing much, then you can also use any 96-98 non-traction module.
2000 s70 GLT
2014 Ram
